Repaired HVAC Unit
Old Jan 22, 2021 | 05:25 PM
Davko298's Avatar
Davko298
Default Repaired HVAC Unit
I'm new to this forum, just purchased my C5 a few months ago. When I first drove my 2000 Coupe, I noticed the HVAC unit lights were out. This forum was amazing in providing me with the information to make decisions on how I would resolve the issue. Not only were there threads regarding my problem, but lot's of "You Tube" videos that helped me think through my options. I went back and forth regarding sending my unit out for repairs and learning to solder (and repairing the unit myself). Ultimately, a forum member (Sean_emory) provided me with the solution that was cost efficient and time efficient! I sent my unit out to "Automotive Circuit Solutions". For $80, and shipping, the control display was repaired and all lights replaced with LED bulbs. They received the unit at 12:43 PM on a Tuesday, and had it repaired / back in the mail at 3:40 PM that same day. WOW - It's working great now!
I couldn't be happier to be a Forum member, and hope someday I'm part of someone's solution like so many of you were for me (Special THANKS to Sean_emory). Now that my HVAC lights work, on to my next research - I'd like to improve the sound a little. Will be exploring Z06 CAT Backs and other options! FYI - I love this car
Old Jan 22, 2021 | 06:11 PM
BKbroiler's Avatar
BKbroiler
Vettetronics did the same thing for my C5 for $65, just fyi.
Old Jan 22, 2021 | 07:14 PM
Sean_emory's Avatar
Sean_emory
You’re welcome!
Glad it’s working well it really makes the car more enjoyable when you fix the small things.
Old Jan 24, 2021 | 12:07 PM
Capn Hook's Avatar
Capn Hook
My 2¢, you should’ve tried the repair yourself. I just did mine 2 weeks ago. Couldn’t have been more straightforward and simple. You already had the hard work done with the actual removal of the unit. Wouldn’t have been much more work to unscrew 4 screws and heating up a solder iron. Glad your happy either way!
Old Jan 24, 2021 | 06:49 PM
Just another example of why this forum is so good - tons of valuable info is available to help keep your car in too shape.
Old Jan 26, 2021 | 12:54 AM
Mav67's Avatar
Mav67
I’m having the same issue do you have the contact info on this repair?
Old Jan 26, 2021 | 10:38 AM
knewblewkorvette's Avatar
knewblewkorvette
Old Jan 26, 2021 | 12:14 PM
Davko298's Avatar
Davko298
I used Automotive Circuit Solutions. Hopefully this link will work, their website explains the process well. Lots of excellent U-Tube videos on how to take the unit out of the vehicle.
1997-2004 Corvette C5 Climate Control Display Repair + LED Upgrade – Automotive Circuit Solutions
Old Jan 26, 2021 | 12:26 PM
ArmchairArchitect's Avatar
ArmchairArchitect
Banned Scam/Spammer
From: Philadelphia PA (Birthplace of the USA, UNESCO World Heritage City)
I had mine done for around $50 via a reputable seller on ebay (for anyone currently looking to get this repair done):
https://www.ebay.com/sch/i.html?_fro...acat=0&_sop=15
Old Jan 26, 2021 | 12:39 PM
MWWarlord's Avatar
MWWarlord
St. Jude Donor '21-'22
I'm so glad that you've had a good experience. We're happy to have you here on the forum. Since you mentioned that your next project is to improve the sound, you may want to search the exhaust bypass mod. This is the cheapest way to make a noticeable difference. This option will also have absolutely no drone. It's not as dramatic a difference as some options, but depending on how loud you want it, it could be a great option for you.
Old Jan 26, 2021 | 02:02 PM
DDaaryl's Avatar
DDaaryl
I hated the thought of sending part of my car away to someone I don't know so I did it myself. Several u-tube videos made this 3 beer job easier.
Old Jan 26, 2021 | 05:55 PM
Mav67's Avatar
Mav67
Thanks for sharing I need this done as well!
Old Jan 26, 2021 | 06:52 PM
Sean_emory's Avatar
Sean_emory
Just for the people who are trying to do this on their own I wanted to share what happened to me. It was my first time learning to solder and I got the dim light display fixed but had lots of trouble removing and replacing the small bulbs. I fried the circuit board somehow and it was unrepairable.
When I sent it out to be fixed they thought it was alright But the fan speed bars and “EXT” were not visible. And also the unit would not shut the lights off after the car was turned off. I think it’s worth it for a professional to make the repair with a warranty unless you’re experienced. And I’m just sharing my experience with this company that they were professional with fast turn around. And they actually have customer service and are a real company. Answered the phone every time I called and were friendly.
Old Jan 29, 2021 | 11:59 AM
grinder11's Avatar
grinder11
I have the same situation as you, except my EXT and fan bars work. I fixed the dim display, and it works great. But I had no luck with the bulbs, which I'm sure you know is the hardest part of the job. I checked all 14 new lights I installed for continuity before soldering, and all tested good. But of the 14 I soldered in, maybe 2 still work. I did have 2 of the 14 working before I "fixed" it. But hardly any light comes from the unit at all. I'll pull it again, and see what's up. I'm concerned something was cooked on the board even before I messed with it, and may still be, hence the bad lighting.......
To Repaired HVAC Unit
