Kooks Installed
Old Jan 22, 2021 | 06:46 PM
FR-CYA's Avatar
FR-CYA
Default Kooks Installed
Installed a set of Kooks Headers and Xpipe on a C5Z. Perfect fitment!
Old Jan 22, 2021 | 07:19 PM
Mike98SilVert's Avatar
Mike98SilVert
Active Streak: 90 Days
I Installed a set Kooks long tube headers with the hi flow green cats on my '99 M6 Coupe about 4 1/2 years ago. Everything installed easily without having to jack up the engine or disconnect the steering shaft or remove the starter. Just moved the alternator aside, unbolted and moved the ground strap out of the way and they slip up from underneath in seconds. They fit perfectly with absolutely no clearance issues and no air tube modifications necessary. I had mine ceramic coated for heat and appearance. Great products and I highly recommend Kooks.
Old Jan 23, 2021 | 01:13 PM
FR-CYA's Avatar
FR-CYA
Great feedback! I had the same experience.
Old Jan 24, 2021 | 06:55 PM
Congrats on the install. Should make a nice difference in your car’s performance.
Old Jan 25, 2021 | 01:02 PM
grinder11's Avatar
grinder11
https://youtu.be/kE2WQQQ5Tpc
Yup. You get what you pay for. I bought Kooks 1-7/8" LTs, their 3" X-Pipe, and Flowmasters over 15 years ago. Fit perfect, still on the car after all these years.
To Kooks Installed
