[Z06] Need some part numbers
1 - Passenger Mirror Glass. Mine is heated. Its cracked so going to pop it out and replace. Part number looks to be 12530714.
2 - Needing the clip for the key lock in the drivers door. I think I bent it up some. So going to get a new one. Looks like this.
https://www.ebay.com/itm/1997-2004-C...-/312310417957
Part Number on that comes up as 16600277. Gm says it does not fit. Seems to be a common piece that was used for years.
3 - Might get these from a local part out place. But there are two covers that give you access to the mirror nuts on the door. Square plugs. Picture of where they are supposed to be here is below. No part number found.
4 - There are some bushings on the bottom of the doors for the window track. My drivers side is bad. Picture below. Vette part out place might have these as well. Cant find the part number.
Drivers side broken. Ignore the fiberglass matting. Its much better now. I can slide the rubber down but after one up and down with the window it comes back off.
Broken piece of rubber.
What the passenger side looks like.
http://shelor.net/Z/CorvetteForum/Docs/C5-PartsManual/
Download the file under the .rar files named C5-PartsManual.zip (124mb).
