Need help with reassembly
Old Jan 26, 2021 | 06:47 PM
Sean_emory's Avatar
Sean_emory
Default Need help with reassembly
I need a picture of how the metal piece in the photo below attaches to the dashboard. If anyone could help that would be great.
Old Jan 26, 2021 | 07:08 PM
lewislgZ06's Avatar
lewislgZ06
NCM Lifetime Member
St. Jude Donor '18 thru '26
This is the best I have got Sean.
Contact forum member JGM2 if this doesn’t help.
Old Jan 26, 2021 | 08:12 PM
Sean_emory's Avatar
Sean_emory
Thank you for responding Lewis.
Here is a photo of where the dashboard connects to the bracket. I am holding it in place because it was broken by the previous person who took the dashboard off (they managed to break quite a few things). So my plan is to plastic weld it back on. But I am still confused how they attach. What kind of screw is supposed to go here?
It looks like the thing sticking out under the oval is a tab but a photo or explanation would really help.
Old Jan 26, 2021 | 08:24 PM
lewislgZ06's Avatar
lewislgZ06
NCM Lifetime Member
Every screw that holds the dash in place is the same except for the 2 on the very top next to the A pillars. They are shorter, but the same size head.
Old Jan 26, 2021 | 08:29 PM
Sean_emory's Avatar
Sean_emory
I still don’t see how these two pieces attach. Maybe a speed nut is missing?
Old Jan 26, 2021 | 08:43 PM
lewislgZ06's Avatar
lewislgZ06
NCM Lifetime Member
Maybe you need to send me a another picture of that black plastic piece that is broken from a few feet away so I can make sure we are on the same sheet of music.
I am thingking that piece that you are gluing back on meets up with that metal tab when the dash is in the car. The screw goes though it and into the metal tab hole.
Old Jan 26, 2021 | 09:02 PM
lewislgZ06's Avatar
lewislgZ06
NCM Lifetime Member
They are self tapping screws
Old Jan 26, 2021 | 09:45 PM
SilverC54me's Avatar
SilverC54me
Can you take a better picture of the dash area in question. Need it a bit further back, should show the door opening to the center stack.
I am thinking you may have something out of alignment.
Gary
Old Jan 27, 2021 | 11:05 AM
Sean_emory's Avatar
Sean_emory
Gary
Here are better photos. I’m sure I’m missing something to make these two things attach.
Old Jan 27, 2021 | 11:13 AM
lewislgZ06's Avatar
lewislgZ06
NCM Lifetime Member
Sean, PM me your phone number and I'll give you a call.
Old Jan 27, 2021 | 01:34 PM
rjacobs's Avatar
rjacobs
That is what the knee bolster screws into... behind the trunk pop button...
Unless we are looking at different things.
Old Jan 27, 2021 | 02:42 PM
lewislgZ06's Avatar
lewislgZ06
NCM Lifetime Member
Finally found a photo of where the plastic tab mounts to the metal fastener with the 7mm screw.
Here is a link with instructions from Corvette Central. Scroll down to this photo.
https://tech.corvettecentral.com/201...-dash-removal/
The knee bolster needs to be removed or down out of the way enough to access it. I was incorrect about accessing this through the hatch release access panel. I've slept since then.
To Need help with reassembly
