Belts and Hoses Maintenance
Old Feb 5, 2021 | 11:44 PM
GoHawks's Avatar
GoHawks
Default Belts and Hoses Maintenance
Purchased my first Vette (2004) last summer and wanting to make sure I have the main maintenance items completed to spend my time once the snow is gone driving, not broken down in the garage. So far I have put on new tires, brakes and had all of the fluids changed (rear diff, coolant, transmission, oil and brakes). Thoughts on needing to replace any belts and hoses and if so which ones? My initial thought was to replace the Serpentine Drive Belt, AC Belt and Radiator Hoses.
Do you agree that after 17 years regardless that they look and feel good that these should be changed? Any others that should be done? Thanks for your input. Great forum!
Old Feb 6, 2021 | 08:37 AM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
I'm overly big on preventive maintenance. Definitely change the belts, and the hoses would be a good idea, too. I have the silicone hoses on my car.
Old Feb 6, 2021 | 08:39 AM
Stingroo's Avatar
Stingroo
St. Jude Donor '20-'21-'22-'23-'24
If they're original. it's cheap insurance.
So I'd change them.
Old Feb 6, 2021 | 09:15 AM
rrwirsi's Avatar
rrwirsi
Do you need to? I bought my '04 with 32K(now have 47K) in 2014. Did not change any belts or hoses after purchase. Each year my go to mechanic inspects them for wear. I did replace the belts when a new HB was installed in 2019. Because my mechanic is not shy, probably on the ultra safe side, telling me things need replacing, I trust his inspection.. All hoses are original.
Old Feb 6, 2021 | 09:48 AM
captaineddie's Avatar
captaineddie
My 2004 with 28K on the clock still has the original belts and hoses. Every year when I have the oil changed I ask my mechanic, who is very knowledgable, if they should be changed. Year after year, it's been the same answer, "the originals are still better than anything that you can buy today."
Old Feb 6, 2021 | 10:06 AM
grinder11's Avatar
grinder11
For those who plan on keeping their car (like many of us), I believe you did the right thing with silicone hoses. If the OP wants to keep his car a long time, that's the way I'd go.....
Old Feb 6, 2021 | 10:09 AM
grinder11's Avatar
grinder11
My 2000 Vert has all original hoses. BUT-I'm going to change them this Spring. Hoses aren't designed to last 21 years. There's no doubt in my mind I'm pushing my luck to the edge of the cliff!!
Old Feb 6, 2021 | 10:10 AM
gnt's Avatar
gnt
Junior Member
USAF
Like others have said, do you have to? Maybe, maybe not. It depends on the condition of the items and the level of risk you’re willing to accept. Rubber parts will deteriorate with time which can accelerate depending on how the vehicle is stored when not being driven.
I bought my 2001 Vert in Sept of 2019. I wasn’t willing to trust 20 year old rubber parts or fluids. I changed oil and coolant. I still need to change ATF and differential fluid. I also changed all belts and the upper and lower radiator hoses.
Some may say it’s overkill but it gives me peace of mind that my wife or I won’t get stranded by something that was incredible simple to change.
Old Feb 6, 2021 | 10:13 AM
royal flush's Avatar
royal flush
01 Z--manager at chevy dealer--all original belt hoses--says like new--waste of money--
Old Feb 6, 2021 | 10:22 AM
1bdvet's Avatar
1bdvet
U.S. Air Force
St. Jude Donor '05 thru '26
I think it up to you, that said, I have 2005 Corvette. I replaced serpentine bolt for GP, and the bottom radiator hose started to leak, all other hoses inspected and plenty of life left on them.
I did replace all 4 TPMS, when one started giving me crazy reading, back in 2019.
Old Feb 6, 2021 | 10:29 AM
Asymptomatic's Avatar
Asymptomatic
Cruising
I would take a look at your belt tensioner and idler pulley as well. Its an easy fix, and you might want to consider it if you are going to take your belt off anyways.
Old Feb 6, 2021 | 10:30 AM
knewblewkorvette's Avatar
knewblewkorvette
I still have all original belts and hoses in my 02 (37k miles). No issues what-so-ever but I do plan on replacing all this Spring when I get the harmonic balance changed out. I'll be going with the silicone hose kit.
Old Feb 6, 2021 | 10:48 AM
Mr. Black's Avatar
Mr. Black
No Hostility Be Happy
I also have the original hoses on my 97. They are low mileage though and stored inside. If you spend a lot of time in your engine bay and do simple visual inspections these modern hoses can last a very long time before needing to be replaced.
If you are of the type that rarely looks in your engine bay then I would recommend changing all the belts and hoses.
Old Feb 6, 2021 | 11:53 AM
I would definitely replace the belts and it would not be a bad idea to go ahead and swap out the hoses while you are at it. The ones currently on the car may be fine for a while, but considering their age, you just never know when they may cause problems.
To Belts and Hoses Maintenance
By Michael S. Palmer | 2026-06-03 09:39:05
