Hi all, if I remove my factory radio, take it apart to clean it and put it back in, will I need the anti-theft code to turn it back on correctly? I have a couple buttons that are sticking, and the CD player skips a lot.
Is there a way to get the anti-theft code from the radio before I unhook it?
Thanks!
The following procedure will give you a new code that you can use instead of your personal code. Using this new code, you can “unlock” your radio and then “re-lock” it with a new code if you wish. Prerequisites: The radio must be in LOC mode not in INOP mode. Let me explain. If you have activated the Theft-Deterrent feature of your radio and loose power, the radio goes into LOC (theftlock) mode. With the ignition on, you must use the MN and HR buttons to enter you personal code in order to unlock it (The instructions are on page 3-27 in your Y2K Owner’s manual). If you fail to enter the correct code eight (8) times, the radio goes into INOP mode. You have to wait an hour with the ignition on before the radio returns to LOC mode (go for a long drive somewhere).
Procedure:
Turn the ignition ON (The radio displays LOC).
Hold down the Radio Presets 2 and 3 buttons for six seconds.
The radio display changes from LOC to a three-digit number. Write this number down. Don’t take forever, fifteen seconds max before the next step.
Press the AM/FM button.
The radio display changes to another three-digit number. Write this number to the right of the first one.
You now have a six-digit number, the first three digits are from STEP 03 and the last three digits are form STEP 05
Press 139010 then # (pound). You will be asked to enter your four or six digit code followed by * (start)
Enter the number from STEP 6 then * (star)
Listen to the four-digit number and write it down. It will be repeated twice.
Use the MN and HR buttons to enter the code from STEP 11.
The radio display changes to SEC Your radio is now “un-locked” and usable. The Theft-Deterrent feature is STILL active! If you want to disable it, use the instruction on page 3-27 in your Y2K Owner’s manual. Use the code from STEP 11 instead of your personal code.
I took mine out a couple of times then bought another factory one from adefferent year that had an auxilary port installed. I was concerned I might have issues with that one but it was plug and play. Didn't bother unhooking my battery for any of the removal and replacements.
If your CD player is skipping, you might do what I did- replace the whole CD mechanism! I bought one off the auction site for less than $25 shipped! It's a very easy job when the radio is out. Manufacturer part number is 09379501. Just search for it. I did all this while I was installing a "aux-In device." Now I can play CDs without skipping, and I can play my ipod or other music device.
Good Luck!
Five years later found your post and took your advice, worked perfectly and easier they dealing with the internals of the CD player. 09379501 is still plentiful on eBay and costs the same as a decent lunch. Bought mine from "replacementradios.com".
