I purchased new tires recently. They are Firestone Firehawk Indy 500 The tire tech put 35 PSI in the tires.
Should I put the 30 PSI in these tires
Thanks for your imput
My wear line is usually perfect at 32-35psi, and that’s on a road course with street tires. 35 is probably fine around town. You can put them at 30-32 if you want. I usually keep 32-33 all year round.
If they are the stock tire size, on the factory rims, I would go with 30 PSI as this is what's called for. If you've changed rim and tire size, that may change the recommended PSI.
I’m running Michelin run-flats. I like them cold at 27, run hot at low 30. Much better ride and wear. To much air in a run-flat will give you a harder ride.
