Sorry if this topic has been discussed already but I couldn't find it.
I'm new here & going to look at 1998 C5. I'm a big guy at 6'3 & 230lb. I was wondering if you guys are comfortable in the 98? Will I have leg room & head room with the roof on?
I'm 6'3" 275 and can put the seat back far enough to barely be able to touch the pedals. I have driven a few 10 hour nonstop drives and have nothing but joy to report!
I'm 6'4", 212lbs. I've had c4's, c5's, and c6's. The c5 has the most overall space for me. seat all the way back, obviously. I'm comfortable once i'm in the car, but getting in and out probably looks a bit silly to onlookers. i def would not choose to drive any corvette as my daily driver.
Plenty of headroom in a vert or frc in my case.
I've sat in a c7 and c8- those cabins are more cramped. C5 is the way to go as far as space goes from my experience.
5',11" very comfortable. I believe the C5 has more leg room than any other Corvette. If you are a larger person, the C5 is going to be your most comfortable Corvette option.
6'3" 190lbs.. I have the seat positioned so it's forward more and then the entire seat angled back. Perfect for me, plenty of room for legs and just enough height.
I have the seat all the way back with the rear upward seat rake all the way forward. And the telescopic steering column midway out. I wish they would have made the seat adjustment with more rearward travel. But overall--it is comfortable.
6'4" and 260 pounds. Other than getting in and out, I fit really well. The only issue I have is my helmet rubs on the headliner/roof when I'm racing it.
6' 3" 195lbs athletic build, in '01 Z06. Stock seat all the way back and down, and angled as far back as it goes. Had to tilt the steering wheel up a notch higher than I'd prefer to make room for my legs. After redoing the seat foam there's not much clearance for my head. I think the Z06 roofline slopes down sooner than hatchback, making it worse for taller drivers.
