Anyone Recognize this Shift K**b?
Old Apr 6, 2021 | 12:26 AM
thedobe2000's Avatar
thedobe2000
Default Anyone Recognize this Shift K**b?
I had picked up this k__b and mgw shifter from the C6 forum but have not been able to figure out how to secure k__b to the shaft. I have not found any mgw k__bs which look like this one so I'm not certain who makes it.
Before I give up and just purchase another k__b that would fit the C6 shaft, I was wondering if someone might recognize this brand of shift k__b and know how to access allen key that is located inside the shaft.
Based on the indentations on the shaft, the key would appear to serve as a set screw to lock the k__b against the shaft. It appears that the k__b could be made of an upper and lower section but that's just a guess on my part as I cannot unscrew the upper half from the lower half of the k__b to expose the key even after spraying the seam with liquid wrench.
Any thoughts would be appreciated.
Thanks for all the help in advance.
Old Apr 6, 2021 | 07:46 AM
Autoeng's Avatar
Autoeng
Why not write ****???
Old Apr 6, 2021 | 09:05 AM
walleyejack's Avatar
walleyejack
yes.. it is a round ****
Old Apr 6, 2021 | 03:49 PM
jackthelad's Avatar
jackthelad
Some devices/software treat "****" as if it was a cuss word. OP may have had no control over what was posted.
Old Apr 6, 2021 | 04:13 PM
thedobe2000
Default Shift k**b.....
Now do I feel embarrassed.... I had noticed most forum members avoid using the actual word in posts that I had seen and just thought that was proper forum protocol.
Well now I am better informed and won't make that mistake in the future!!
Thanks!!
Old Apr 6, 2021 | 06:41 PM
F1Fan's Avatar
F1Fan
I thought we were going to find out you were in the UK!
Old Apr 7, 2021 | 12:54 PM
GoldenFlame's Avatar
GoldenFlame
Thanks!!
I think you only see that if you aren't signed in
Old Apr 7, 2021 | 08:04 PM
~Josh's Avatar
~Josh
Banned Scam/Spammer
I’ve got a polished ****.
Old Apr 7, 2021 | 08:45 PM
walleyejack
Old Apr 7, 2021 | 09:10 PM
lewislgZ06's Avatar
lewislgZ06
NCM Lifetime Member
St. Jude Donor '18 thru '26
^^^^That’s a good one!!!
To Anyone Recognize this Shift K**b?
