stuck oil drain plug
Old May 1, 2021 | 08:39 PM
corgasm's Avatar
corgasm
Default stuck oil drain plug
Hi, I have the car on ramps and can get a wrench on the drain plug but can't get enough clearance/leverage to free the bolt. My thought was to put a jack under the wrench to get the required oomph. Since I have a history of making things worse what do you think of this idea: genius or dumb?
Thanks, Larry
certified DIYer . . . Destroy It Yourselfer
Popular Reply
May 1, 2021, 08:49 PM
Mr. Black's Avatar
Mr. Black
No Hostility Be Happy
Make sure you are using a tight fitting 6 point wrench. 12 point is bad in this case.
I would either double wrench creating a breaker bar or I would hit the one wrench with a hammer. Shock is your friend.
Old May 1, 2021 | 08:42 PM
redzg's Avatar
redzg
I have used the technique to loosen an otherwise impossibly tight lug nut before -- but -- silly as this may sound -- double or even triple check that lefty is loosey and righty is tighty. Break a wheel stud, the other four get you to the garage. Strip the oil pan, not so much...
Old May 1, 2021 | 08:49 PM
Mr. Black's Avatar
Mr. Black
Old May 1, 2021 | 08:51 PM
Smoken1's Avatar
Smoken1
Stick a piece of pipe on the wrench to make it longer
Old May 1, 2021 | 10:41 PM
DWAVette's Avatar
DWAVette
Mr Black is on track. My 99 Vert had an insanely tight oil pan plug when I got it last year. Got a good quality, 6-point. Held it snug, and began striking the wrench with progressively harder strikes until it broke free. It did not go back on that tight.
Old May 1, 2021 | 11:01 PM
Big Olly's Avatar
Big Olly
Cruising
Best chance to not round the head is using a 6 point wrench and turning it firmly by hand while striking it rapidly with moderate force with a rubber hammer. Run the car till the oil gets up to temp first then turn it off and do it while the oil is still hot too. Just don't get it all over yourself. Brake it out but leave the plug in loosely until it cools down if you're worried about it.
Old May 2, 2021 | 12:24 AM
A piece of pipe over the wrench helps create more force (torque) for breaking the bolt free.
Old May 2, 2021 | 07:18 AM
Stingroo's Avatar
Stingroo
St. Jude Donor '20-'21-'22-'23-'24
When I first got my car and went to get the oil changed, the gorilla who had done it before me had it so tight that the only way I got the plug out was using an air hammer on the flats to forcibly spin it.
This, and many other reasons, is why I do all my own work.
Good luck with yours.
Old May 2, 2021 | 10:22 AM
grinder11's Avatar
grinder11
Thanks, Larry
I agree with other posts. But-If the hex is totally rounded, you may have to resort to vice grips set VERY TIGHT, or even a small pipe wrench. I'm sure you'll get it. However, if you have the front end elevated, you won't get all your old oil out. Actually, the recommended procedure on the C5 is to have the REAR ELEVATED an inch or so higher than the front. Once you do get that plug out, if the hex is rounded, just pitch it, and buy a good magnetic drain plug. Just order the mag plug ahead of time! Best of luck to you.......
Old May 2, 2021 | 03:13 PM
1wholikescars's Avatar
1wholikescars
If it's really on and starting to get stripped, I used Bolt extractors on the head. They will bite and not give.
Amazon Amazon
If you are not stripped, I'd hit it for a couple of seconds with an impact gun (electric or otherwise) and it should loosen. that's if you can't get a breaker bar on the wrench to muscle it off.
I keep my Ryobi electric impact around for those situations.
Old May 2, 2021 | 08:29 PM
Stingroo's Avatar
Stingroo
Not sure how you'd have room for any kind of power tool on a C5 drain plug. Unless you used a universal joint or two, I guess.
Old May 2, 2021 | 09:58 PM
ValenciaOrange's Avatar
ValenciaOrange
Go to one of those quick lube places. Ask if you can watch so they don’t mess up things. They should be able to loosen it.
Old May 3, 2021 | 06:09 PM
corgasm's Avatar
corgasm
Default stuck oil plug
Thanks for all great suggestions. Just to make sure, on a '99, the bolt loosens left? counterclockwise? So, if I have a wrench on the bolt, and the wrench is pointing toward the driver;s side (parallel to the garage floor) I would move the wrench up, toward the driver's seat? Is that right?
Old May 3, 2021 | 07:13 PM
Mr. Black's Avatar
Mr. Black
That is correct.
Old May 3, 2021 | 08:24 PM
glbeauchamp's Avatar
glbeauchamp
When you reinstall it, the torque is 18 ft/lbs.
Old May 4, 2021 | 08:25 AM
DWAVette's Avatar
DWAVette
On mine, I think the previous mechanic was dyslexic. I am sure it was 81!
Old May 4, 2021 | 08:35 PM
wmupaprmkr's Avatar
wmupaprmkr
Cool Hand Luke of W MI
18 ft-lbs doesn't seem like a lot at all, but that is what the FSM says. When I bought my car mine was on gorilla tight too and I was able to get it off with a quality 6 point socket. Good luck OP!
To stuck oil drain plug
Old Nov 20, 2025 | 08:01 PM
pinehurstgreen's Avatar
pinehurstgreen
4th Gear
Yes, I know this is an old thread. I bought a C5 where a gorilla clearly put the drain plug back in. I used a breaker bar with a good 6-point socket and a floor jack to break the plug loose, and it worked great! Then I moved back to the filter armed for battle with my racketing filter tool and my long-handled ratchet only to find that the filter was installed finger tight by a toddler. So that’s prolly where all the oil under the car is coming from. Now both are installed correctly, and I can move on to the coolant leaks and under-nose damage. Soon I can actually drive the monster.
Old Nov 21, 2025 | 01:25 AM
vette4fl's Avatar
vette4fl
I too know this is an old thread. Just say’n…
Old Nov 21, 2025 | 08:14 AM
hyperv6's Avatar
hyperv6
Thanks for the feedback. I am sure someone will benefit by your experience old thread or not.
