replacement key fob question
Old May 16, 2021 | 10:05 AM
rwlc5's Avatar
rwlc5
Default replacement key fob question
I have a 1999 with passive entry. Is there a key fob without the passive entry feature that will work with my car?
Old May 16, 2021 | 11:44 AM
grinder11's Avatar
grinder11
Yes! If you do NOT want the passive remote function, GM part# 19299230 is the new part#. I believe GM Part# 10432147 will also work. It's the older of the two part#s, so I'd go with the 19299230 if I was buying a used one. For a brand new one, try Cultrag..... Hope this helps..
