Memory erase
Old May 20, 2021 | 06:52 PM
LTCHAPPA's Avatar
LTCHAPPA
Default Memory erase
Is it possible to erase all the memory that you have saved and start fresh? My driver seat stops and starts when I move it forward and back.I think it may be hitting some old settings that I had programmed in over years.
Old May 21, 2021 | 08:56 AM
grinder11's Avatar
grinder11
I don't think so. Im not sure about totally erasing the memory. Usually programming a new setting should suffice. BUT-I think your problem is a dirty potentiometer, under the seat. You have to remove the seat, put it on a bench, remove the potentiometer, clean it, and reverse what procedures you've done to reinstall everything. I had the same problem, and this fixed it. Search is your friend. Best of luck to you.
