Driver Side Mirror Glass Replacement
Old Jun 9, 2021 | 09:02 PM
Thera p's Avatar
Thera p
Default Driver Side Mirror Glass Replacement
My rear view mirror glass is all messed up. Is it possible to replace just the glass? It looks like it’s ‘captured’ by the plastic housing. I’m sure I can break the old one to get it out, but will a new one snap right in? I’m just not finding info on glass replacement only. The posts I’ve found deal with replacement of the whole housing.
Old Jun 9, 2021 | 10:25 PM
Stingroo's Avatar
Stingroo
St. Jude Donor '20-'21-'22-'23-'24
Assuming you have the electrochromatic mirror, you can get just the glass, but it is very expensive. I opted to just get the stick on regular mirror glass for a few bucks. Last I looked, the auto dimming one was like $300+ and that just wasn't worth it to me.
Old Jun 9, 2021 | 10:36 PM
K9Leader's Avatar
K9Leader
I have this and it makes it much easier to check the blind spot. Offered by at least these two sellers - there may be others as well:
https://www.zip-corvette.com/97-04-p...4aAsMpEALw_wcB
https://www.ecklerscorvette.com/1997...caAnGdEALw_wcB
Old Jun 9, 2021 | 10:38 PM
Stingroo's Avatar
Stingroo
Wow never seen those before. I may have to place an order.
This forum never ceases to cost me money
Old Jun 10, 2021 | 08:13 AM
Thera p's Avatar
Thera p
I’m not sure if it’s auto dimming or not. If it is, I’ll just replace with plain glass.
The stick on approach is a good option, but I’d still like to know if & how the glass can be replaced.
Old Jun 10, 2021 | 10:38 AM
Stingroo's Avatar
Stingroo
The glass just pulls off the housing. Held in with clips:
If you're talking about replacing JUST the glass itself and using the original black trim around it, no, can't be done.
Old Jun 10, 2021 | 12:20 PM
Thera p's Avatar
Thera p
OK. That’s what I wanted to know. But I know I’ve seen JUST the glass for sale. Seems odd if it can’t be replaced.
Old Jun 10, 2021 | 12:28 PM
MWWarlord's Avatar
MWWarlord
St. Jude Donor '21-'22
I hadn't seen these before. Might be worth a try. Stingroo, let me know what you think of them.
Old Jun 10, 2021 | 12:54 PM
Thera p's Avatar
Thera p
A supporting member was selling a stick-on piece a few years ago. Anyone have that or know who was the seller. It wasn’t Eklers or Zip.
Old Jun 10, 2021 | 02:01 PM
wdcraig's Avatar
wdcraig
Thank you very much- I have been putting this off and living with the messed up auto-dimming mirror for 4 years. Made in USA- and the improved panoramic rear view- sold me. I'm looking forward to looking behind!
Old Jun 11, 2021 | 12:28 AM
Ed Ramberger's Avatar
Ed Ramberger
I have auto-dimming/memory/heated. When the glass went bad, I just bought a replacement GM memory/heated. Depends on where you find it will be in the $100 range +_
Old Jun 11, 2021 | 07:32 AM
Stingroo's Avatar
Stingroo
Significantly more than that now. Like two to three times that amount.
Old Jun 11, 2021 | 10:20 PM
Here is a file on replacing the glass on the outside rear view mirror. I have also included a couple of other files that may help, but I did not check them over first - just went by the file name.
Old Jun 11, 2021 | 10:58 PM
Mickeyrx70's Avatar
Mickeyrx70
Stick-on mirrors are available on eBay for $15 or so. I’ve had one nearly 10 years without a problem.
Old Jun 12, 2021 | 08:52 AM
Thera p's Avatar
Thera p
Good info here, - thank you! But I’m still a little confused. Member Stingroo says it’s not possible to replace JUST THE GLASS. Meaning you can’t put new glass into the black plastic backing housing. But you can purchase JUST the glass. I would still like to hear from other members on this.
Old Jun 12, 2021 | 08:56 AM
Stingroo's Avatar
Stingroo
Cleaning the liquid from between the two pieces of glass like in the 3rd document would eliminate the autodimming feature. So you can't replace just the glass AND keep the auto dim. Rather than go through all that headache to get the same result, my stick on mirror has survived two years, 20,000 miles, and 150mph on multiple occasions.
Old Jun 12, 2021 | 10:07 AM
Thera p's Avatar
Thera p
I don’t care about the heat or auto-dim feature. The question was (and still is) whether it is possible to replace JUST the glass in the black plastic surround/backing piece. You said it’s not possible. Other info seems to suggest it can be done.
Stick-on is still an option. But I’d like to keep the OE look if I can.
To Driver Side Mirror Glass Replacement
Old Jun 12, 2021 | 10:36 AM
helga203's Avatar
helga203
"If you're talking about replacing JUST the glass itself and using the original black trim around it, no, can't be done."
is this what your looking for?? or im i not understanding you??
Old Jun 12, 2021 | 10:58 AM
Thera p's Avatar
Thera p
Yes, that’s what I want to know. I’m getting conflicting info. Ive been told to heat the black trim to remove the glass, then glue in a new piece. Has anyone on here done this?
Old Jun 14, 2021 | 02:39 PM
wdcraig's Avatar
wdcraig
Default Panavex Mirror Before and After
