Head Light Bounce
Old Jun 14, 2021 | 08:02 AM
Constpm1's Avatar
Constpm1
3rd Gear
Default Head Light Bounce
Looking for some suggestions. My drivers side head light seems to bounce quite a bit when I am driving at night. There is some travel 1/4" when I grab it with my hand. How can I tighten this up? Is it missing a spring or something?
Old Jun 14, 2021 | 08:17 AM
Moved to C5 Tech.
Old Jun 14, 2021 | 08:31 AM
vetteLT193's Avatar
vetteLT193
Do some searching here... there are a bunch of threads on it and it pretty well narrows it down to a pin or a loose or missing bolt(s)
Old Jun 14, 2021 | 11:33 AM
MWWarlord's Avatar
MWWarlord
St. Jude Donor '21-'22
This is not normal. There should not be any play in the lights.
Old Jun 16, 2021 | 01:31 PM
Gunfighter77's Avatar
Gunfighter77
Could also be one of the adjusters is broken. Suggest a search as lot of threads on this.
Old Jun 17, 2021 | 05:31 PM
97SLVRC5's Avatar
97SLVRC5
Take the headlight bezel off and then the coverl. You'll need a Phillips head and a T15 TORX bit. Bezel comes out first, if I recall - there's a guide at the top so pull the top of the bezel out towards you and then tilt it downwards. Angle the bottom of the bezel so it comes out. No force needed - will take less than a minute once you see how it sits in there. Then use the T15 for the cover - open your hood so it's easy to lift it up and off - don't use force, just wiggle if need be. (This is also the easiest way to access signal bulbs without a lift, as well.)
You said you can induce travel with your hand - now you should be able to see where and why.
Old Jun 17, 2021 | 05:39 PM
Velocity_Vette's Avatar
Velocity_Vette
You need to check that the isolators (sometimes called bump stops) on the head light are still present. There are four total for each head light, two are on the pivot arm down low, and two are immediately on the "top" of the head light body door between it and the hood.
If one or more than one is missing it will cause the headlight to bounce around.
Old Jun 18, 2021 | 07:25 AM
Constpm1's Avatar
Constpm1
3rd Gear
Thank you,
I saw those bump stops on the parts break down.
To Head Light Bounce
