Advice on 241 head build
Old Jun 15, 2021 | 09:48 PM
z06Jr's Avatar
z06Jr
3rd Gear
Default Advice on 241 head build
Hey how’s it going guys. I have a Ls1 z06 & finally decided to get a cam kit from Texas speed. I need some advice on what else I would need for this aside from what’s included in the kit. Hopefully you guys can point me in the right direction.
cam kit
- Tsp bald eagle cam 277/234, .600/600 111LSA
- Tsp 7.40 chromoly pushrod
- Tsp polished .600 dual valve spring kit w/ integrated seat/seal
- Prc titanium retainers
- GM high performance LS oil pump, wet sump
- wet sump balancer pulley, LS front crank seal, water pump gasket, & timing cover gasket
car is basically stock besides kook headers, catted x pipe, & corsa axle back
Old Jun 16, 2021 | 04:12 AM
Tusc's Avatar
Tusc
Running Guns & Moonshine
My advice is made since you sound to be technically proficient and comfortable doing the work.
One thing I now mention is replacing the lifters while you're in there since my last LS6 had one fail and take the block. Relatively cheap insurance.
Stock rockers go a loooong way, but the bearings can fail and many opt to replace the needle bearings with bushings by Straub or Che. Do not use comp.
I don't recall while writing this if you mentioned a new timing chain was ordered or not? With all this work, absolutely do.
Why not also flush all coolant and get a new pump while it's off?
Old Jun 16, 2021 | 04:13 AM
Tusc's Avatar
Tusc
And definitely return to this thread when done and post links to the before / after video of the car. Sounds fun!
Old Jun 16, 2021 | 03:09 PM
z06Jr's Avatar
z06Jr
3rd Gear
thanks for the advice! New timing chain will be ordered as well, in the process of looking for the best one for my set up.
Old Jun 16, 2021 | 03:41 PM
Smoken1's Avatar
Smoken1
cam kit
Did this car have an engine swap done? You should have 243 heads not 241
Old Jun 16, 2021 | 04:58 PM
Steve454's Avatar
Steve454
Purely subjective, but this is one of the best options for a timing chain:
Katech C5R Timing Chain
Old Jun 16, 2021 | 06:12 PM
z06Jr's Avatar
z06Jr
3rd Gear
original engine 60k miles & it’s the first gen 2001 z06 maybe that’s why they’re different from the 02-04? I have heard that 243 heads would be best but the 241s are the ones that are on currently. Would the cam kit that I have already work on the 243s? Cause if that’s the case I can go ahead & pick up a set from a buddy of mine.
Old Jun 16, 2021 | 07:25 PM
Tusc's Avatar
Tusc
Re chains, reach out to Bret and see what he has in stock:
https://www.corvetteforum.com/forums...-no-equal.html
Old Jun 16, 2021 | 09:35 PM
redzg's Avatar
redzg
The 241s are going to limit how effective the cam is. Every document I've ever seen indicates all Z06's came with 243s. If you have 241s it raises a whole slew of questions. Since you're going with a good cam, limiting it with the heads is a bad idea -- unless you took the 241 flow characteristics in mind when doing the cam selection?
Old Jun 16, 2021 | 09:45 PM
Smoken1's Avatar
Smoken1
They say pictures are worth a thousand words. Do your heads actually have 241 stamped on them?
Old Jun 16, 2021 | 09:55 PM
PerryKing's Avatar
PerryKing
2020 C6 of the Year Finalist - Modified
Seems odd. I didn’t think the Zs had 241s either. If that’s what you’ve got I’d opt to swap the heads. A set of ported 243s would make a huge difference. The 241s will always hold you back and it’s a PITA to pull the heads again later. Upgraded trunnions if your going to run stock rockers. Timing chain and a harmonic balancer. It really depends on what you want to possibly change later. When I did my build I knew I didn’t want to revisit something I removed and didn’t replace later on. Most people are probably different and wouldn’t just replace a good part. I didn’t want to stress old parts with all the extra HP and wait for them to break.
I also wouldn’t just throw those push rods in without checking for correct length.
Old Jun 17, 2021 | 12:47 AM
Tusc's Avatar
Tusc
Run whatcha got and enjoy it, I say. How limited will you be for 20 hp max?
If you ever did do heads, wait until your got an ARP stud kit.
And wait until you have a blower cam. Because that will be your next stop even if you don't know it yet.
Old Jun 17, 2021 | 07:19 AM
Daveinnola's Avatar
Daveinnola
Check your heads. I have a 2001 Z06 also and my heads are 243. If you have 241 heads on a Z06 then someone swapped them.
To Advice on 241 head build
