04 Fuel Pump life expectancy/replacement
Old Jun 18, 2021 | 09:37 AM
MikeTN77's Avatar
MikeTN77
Default 04 Fuel Pump life expectancy/replacement
Hey guys and gals...I have done a few searches on this topic, with mixed results. I was wondering what kind of life are you guys getting out of the stock pump? Before buying my 04 I did months of research (much of which was on this forum) and finally decided on an 04. I was aware of the crossover fuel fitting leak issue on particular VIN's, and bought one out of that VIN range. What I failed to realize was that GM relocated the pump mid 03 and it is a much more involved repair that I expected. (Trans and Diff removal) How much should this concern me? I have heard of dealer quotes above the 3000 dollar range. I have 88k on the car, stock engine. I keep the tank half full or above, and run Techron through it about once a month. I live in a relatively rural area and reputable Corvette shops are quite a distance away. Just trying to stay ahead of the game on possible future issues.
Old Jun 18, 2021 | 10:16 AM
MWWarlord's Avatar
MWWarlord
St. Jude Donor '21-'22
I would say, keep doing what you're doing, and don't worry about it unless you have a problem. It is a fairly major job on an '04, but $3k is way too high.
Old Jun 18, 2021 | 12:27 PM
MikeTN77's Avatar
MikeTN77
For sure. I called my local dealer just for kicks, and he quoted me 3800. He insisted there were 2 electric fuel pumps, I was thinking the secondary was a venturi style, and the left was the only electric one. I kinda wish I had shopped for an early 03 now...haha
Old Jun 18, 2021 | 12:57 PM
MWWarlord's Avatar
MWWarlord
If it makes you feel any better... My '04 has 98K miles on it, and is supercharged, and I've never had any issues at all with the fuel pump. I do have an electronic fuel pump booster to help deal with the extra demand caused by the blower. As long as you use good gas, keep using Techron per the instructions on the bottle, and don't let your fuel get too low, your fuel pump should work fine for a long time to come. Don't let the fear of a problem that does not yet exist ruin your ownership experience.
Old Jun 18, 2021 | 04:33 PM
MikeTN77's Avatar
MikeTN77
That's good advice, thanks. I'm mid 40's and this is by far the most pleasurable vehicle I have owned. I'd be curious to see how many of the 150-200k C5's on the road have the stock pump. I'm a firm believer in keeping the tank full to preserve pump life, so far I have good luck with my vehicles in doing so
Old Jun 18, 2021 | 11:10 PM
3sACROWD's Avatar
3sACROWD
You are correct that there is only one electric pump. The passenger side has a Venturi pump.
I changed my fuel pump at 200,000 miles. My sending units failed. My pump was working fine. I have an 03 Z06 BTW.
Old Jun 18, 2021 | 11:40 PM
Yello95's Avatar
Yello95
St. Jude Donor '11
Had my noisy pump changed out 5 years ago and it was horrifying but done perfect. I watched the entire job being done...$2000...
Old Jun 19, 2021 | 12:17 AM
wrmiles's Avatar
wrmiles
Fuel pump doing fine at 188k on my 2002. I don't believe fuel level is important unless maybe you were running completely dry repeatedly.
Old Jun 19, 2021 | 08:10 AM
Yello95's Avatar
Yello95
St. Jude Donor '11
...i respectfully disagree...your experience is not typical of most c5 fuel pumps....the fuel pump needs to be submerged in fuel to keep it cool and not have it burn up....therefore you should not let the tank go below 1/4 full.....just my uneducated 02.....
IF you have a 2004, here's what you will be having done if you think fuel level is unimportant...be my guest...
To 04 Fuel Pump life expectancy/replacement
