Front Spring bolt nuts?
Old Jun 19, 2021 | 01:04 PM
DucatiDon's Avatar
DucatiDon
C2 of Year Finalist (performance mods) 2019
2018 C2 of Year Finalist
Default Front Spring bolt nuts?
I finally got my new C5 Z16 up on the lift, and overall it looks really really good.
I was going to try to lower it on the stock bolts, but dont have a 20mm wrench for the rear nut.
Went to the front and found no nuts at all.
Is that a common practice to take the nuts all the way off?
Nevermind. I looked at some others and apparently there is no front nut, its threaded through the spring.
Car doesnt look or feel lowered though.
How much thread should there be at full drop?
Im guessing the lower part of the bolt should be flush with the spring.
Thanks, yall
D
Old Jun 19, 2021 | 04:45 PM
mstromquist's Avatar
mstromquist
2015 C5 of the Year Winner
Screw it all the way in until it bottoms out. Then you'll be lowered all the way and you should see some difference. If you have an all 1/16's wrench (Cresent wrench) then you should be able to get the backs done too.
