Header Question...
Old Jul 8, 2021 | 02:48 PM
saxtonfwd's Avatar
saxtonfwd
Default Header Question...
I know this has had to been asked a million times over, but I am putting Borla S Type and Borla X-Pipe on my 04 Vert with Halltech Venom CAI, what would be the best and cost effective Long Tube Headers with that set up with no other major mod? I will get it tuned once I get the headers on. Thanks in advance...
Old Jul 8, 2021 | 03:02 PM
Smoken1's Avatar
Smoken1
I would get the X-pipe that goes with the headers you are buying
schmuckingham's Avatar
schmuckingham
Depends on budget then what size. Do you plan to go h/c/i or blower anytime soon? You may also run into an issue of what is or is not in stock and when it will be available again.
Old Jul 8, 2021 | 04:01 PM
Smoken1's Avatar
Smoken1
I just bought a set of Kook's 1 7/8 headers with the X-pipe that have cat's but no AIR fittings. I think he said he has 1 more set in stock
Old Jul 8, 2021 | 04:05 PM
saxtonfwd's Avatar
saxtonfwd
Appreciate the answers, I don't plan on modding it beyond maybe a mild cam if I doing any more performance mods. I will look into the Kooks, and here in NC you have to at least have the cats on for visual inspection.
Old Jul 9, 2021 | 06:57 AM
grinder11's Avatar
grinder11
Can't go wrong with Kooks.
Old Jul 9, 2021 | 11:34 AM
MWWarlord's Avatar
MWWarlord
St. Jude Donor '21-'22
Kooks are the best quality, but there are cheaper options as well.
Old Jul 9, 2021 | 11:49 AM
lewislgZ06's Avatar
lewislgZ06
NCM Lifetime Member
St. Jude Donor '18 thru '26
Whatever brand headers you get, I would recommend 1 3/4” unless FI is in your future.
I also believe this is definitely a item where you get what you pay for.
Old Jul 10, 2021 | 07:59 AM
Johnny Hardcore's Avatar
Johnny Hardcore
One more in agreement about Kooks. I've been running them on a C5 since 2007/ 40k miles with a Kooks off road x-pipe. Great fitment, sound and power gains. Also running them through Borla S type Stingers with single tips. Car sounds amazing in my opinion and has gotten countless compliments on the exhaust note.
Mentioned above, if you ever plan to go FI buy the 1 7/8s. If NA is your goal the 1 3/4 will net you better low end torque on NA builds, and cost you a little less. If FI is a remote possibility future state...buy them once and go with 1 7/8s. You'll sacrifice some torque and hp while NA with 1 7/8s, but make up for it when you decide to boost. (spoken from experience)
As one of the other guys mentions above...match your x-pipe to your header brand to ensure proper fitment up front. Most "quality made" x-pipes bolt up easily to any axle back exhausts.
Old Jul 10, 2021 | 06:31 PM
grinder11's Avatar
grinder11
with buying quality, especially on key items, like pistons, headers, etc. I almost went with Kooks 1-3/4", but I ended up with an LS7, so I went with Kooks 1-7/8" instead. But the key thing is I went with Kooks. There are others as good, or maybe a bit better. But I've had cheapo headers in the past. Leaks, fitting problems, clearance problems, you name it. Getting cheap headers to fit and not leak can be....uh.....exhausting. Sorry, couldn't resist 😅
Old Jul 11, 2021 | 02:48 AM
CorvetteBrent's Avatar
CorvetteBrent
If you can afford Kooks, that's the way to go, in my opinion. If money is an issue, then go with Flowtech headers with Flowtech X-pipe.
Old Jul 11, 2021 | 08:38 AM
90lxtc's Avatar
90lxtc
Kooks and ARH are about three top. I bought LG pro 1 3/4s and fitment is poor. I’m still waiting to get them replaced or even better a refund. I don’t think I would buy anything else LG ever again unfortunately. The entire experience has sucked.
Old Jul 11, 2021 | 09:31 AM
wydopnthrtl's Avatar
wydopnthrtl
Based on no more big mods... Stainless Steel and 1.75" primaries. The mid pipe size and shape is where you'll develop the sound. I like to have a large and smooth mid pipe and then tone it down w/the after cat.
Old Jul 12, 2021 | 03:17 PM
grinder11's Avatar
grinder11
That's surprising. Though I've never bought anything from LG, I've also never heard anyone complain before about LG headers fitment. Maybe they have, and I didn't see it. Two worst things dealing with almost ANY company today are:
1. Their customer service SUCKS, and
2. Once they have your money, you'll have a HELLUVA time getting a refund.
If the LG headers don't fit your car, LG should send a prepaid 'shipper', and pay for the return shipping. You would think they'd want to find out WHY they didnt fit. Or issue a refund upon their return!!
Old Jul 12, 2021 | 04:30 PM
Mike98SilVert's Avatar
Mike98SilVert
Active Streak: 90 Days
Default My personal experience
I installed a set of Kooks long tube headers with the hi flow green cats on my '99 M6 Coupe about 5 years ago. Everything installed very easily and without having to jack up the engine or disconnect the steering shaft or remove the starter. Just moved the alternator aside, unbolted and moved the ground strap out of the way and they slipped up from underneath in seconds. They fit perfectly with absolutely no clearance issues and no air tube modifications necessary. I had mine ceramic coated for heat and appearance. I highly recommend Kooks.
Old Jul 12, 2021 | 06:18 PM
90lxtc's Avatar
90lxtc
Solid reputation is why I went with LG to begin with. But it was all down hill from there. I purchased in early May and STILL do not have the hi flow cats I paid for. I sent them a picture of my issue and was told by LG that they certainly should not be fitting like they are. (Merge collector hangs 2” below the floor pan) They were supposed to be putting a pair of the headers from the same batch on a shop C5 to see if it’s a batch issue. However each time I call it’s a different story. I’m close to the point I’m going to ask for a refund and just buy Kooks and call it a day…
As for customer service. Yes since covid most things in the manufacturing department now suck. Unemployment payout is high and people don’t want to return to work and cost of materials is also high. I hear those reasons a lot.
I will However say that the quality of material used on the entire exhaust is great. The SS tubing used is thick.
Old Jul 12, 2021 | 08:13 PM
smitty2919's Avatar
smitty2919
TPS RPM 1 7/8" with matching X pipe. Amazing fitment, no install issues and tuck up very high.
Old Jul 12, 2021 | 09:18 PM
90lxtc's Avatar
90lxtc
I almost bought them. Watched their video too. They do tuck very well. As it sits now if my car was lowered I would be sparking like a low rider truck with drag blocks.🤣
Old Jul 13, 2021 | 03:58 PM
smitty2919's Avatar
smitty2919
If you are low enough to drag TPS headers then you are WAY too low and are doing worse to your shocks and geometry which kills handling...
To Header Question...
