Key fob issue
Old Jul 19, 2021 | 05:44 PM
djohn3853's Avatar
djohn3853
St. Jude Donor '21
Default Key fob issue
So a couple weeks ago I installed a K&N filter. The first step is remove the negative battery cable. The battery was disconnect 3-4 hours.
Ever since, my key fob has worked sporadically (or maybe not at all).
I thought at first i had a car battery issue, but the car always started, so I thought it was key fob battery possibly.
I removed battery and couldn't get any voltage reading.
Ordered replacement cr2450 from Amazon (I'm lazy).
Put in the new battery today, and nothing. won't open the doors or trunk.
Do I need to program/train the key fob thru the dic?
Old Jul 19, 2021 | 06:02 PM
popshumphrey's Avatar
popshumphrey
St. Jude Donor '16
I think you will need to retrain the FOB. Its pretty easy and there are lots of you tube videos as to how. I would tell you but Im old and forget all the steps.
Old Jul 19, 2021 | 06:07 PM
knewblewkorvette's Avatar
knewblewkorvette
The instructions on how to program is also in the owner's manual
Old Jul 21, 2021 | 02:26 AM
laurent_zo6's Avatar
laurent_zo6
St. Jude Donor '15-'16-'17-'18-'19-'20-'21-'22
From my file from another Corvette Forum member:
You do not have to see a dealer to re-program the FOBS. It is very easy.
1. Turn ignition on. (Engine Off)
2. Turn radio off.
3. Press Driver In formation Center(DIC) RESET button.
4. Press OPTIONS button on DIC until display is blank.
5. Press and hold RESET button for 3 seconds.
6. Press OPTIONS button until FOB TRAINING i s displayed.
7. Press RESET button to begin programming sequence.
8. Simultaneously press and hold LOCK and UNLOCK buttons on first remote for 13 seconds. Message will
appear when remote is programmed. Repeat this step for additional remotes.
9. Turn ignition off and remove keys from ignition.
10. Test remotes.
Old Jul 21, 2021 | 09:27 AM
djohn3853's Avatar
djohn3853
St. Jude Donor '21
2. Turn radio off.
10. Test remotes.
This is exactly what I did, successfully. Regarding step 8 above, I did not realize it would take 13 seconds. After about 3 seconds, i felt like it wasn't working. But then it worked, thankfully.
One thing i've noticed since: It seems like when i'm near the car sometimes, the horn blows (like the car was locking itself) never did this before.
Old Jul 21, 2021 | 11:33 AM
MWWarlord's Avatar
MWWarlord
St. Jude Donor '21-'22
I agree, just retrain the FOB and you should be fine.
Old Jul 21, 2021 | 11:35 AM
MWWarlord's Avatar
MWWarlord
If you have an older C5 then you have passive keyless entry. This may be what is happening.
Old Jul 21, 2021 | 11:40 AM
djohn3853's Avatar
djohn3853
St. Jude Donor '21
Yes, I have a 99. The fob has a slider for passive and I believe its off and has been since ive had it. I actually never noticed the little slider until I had this issue and replaced battery.
I haven't touched the slider because I don't know what will be different.
To Key fob issue
