[Z06] Flat tire in a Z06
Old Dec 19, 2002 | 08:48 AM
ThePurpleKing's Avatar
ThePurpleKing
Default Flat tire in a Z06
Has anyone had to use the flat tire kit? Does it work? Seems like a Mickey Mouse solution to a potentially Superman problem.
Old Dec 19, 2002 | 11:07 AM
HummelS's Avatar
HummelS
Default Re: Flat tire in a Z06 (ThePurpleKing)
I haven't used the goop, but the pump works if you have slow leak (nail) and need to get a few miles to get it patched. But you're right - anything major, you better have a cell phone....
Old Dec 20, 2002 | 12:34 AM
FLYNLO's Avatar
FLYNLO
Default Re: Flat tire in a Z06 (thevettenet CA)
I think anything major on runflats would cause you the same problem. What I have decided to do was get a plug kit from Autozone for less than 10.00 bucks. We had a group out driving one day and one of the coupes(runflats) got a DIC message that he was loosing pressure. We checked and sure enough, there was a very small hole. Instead of driving on the sidewall, a couple of our forum members teamed up and was able to plug that puppy and he could drive home with a little more confidence. I was sold on the plug kit.
John
Old Dec 20, 2002 | 03:02 AM
HirPowerZ06's Avatar
HirPowerZ06
Dont use the glue it is very messy ,try getting it off after you use it SUCKS keep a plug kit handee :cool:
Old Dec 20, 2002 | 04:03 AM
HummelS's Avatar
HummelS
Default Re: Flat tire in a Z06 (FLYNLO)
I think anything major on runflats would cause you the same problem....
John
Nope - I know of a couple of people who have taken major sidewall damage with the runflats & managed to drive 50+ miles on back roads with a hole that no plug kit or patch would ever repair. We're talking 1/2" gashes here, zero air pressure, and the runflats will get you home, or at least to the nearest tire store.
I think the point of the original post was that with that sort of damage to a Z06 tire, the pump and goop is pretty much worthless - the tire's probably off the rim and shredded at that point anyway. :seeya
Old Dec 22, 2002 | 04:32 AM
Fast Lane's Avatar
Fast Lane
CI 3-4-5-6-7-8-9-10 Veteran
:cuss Found a nail in my rear tire today. Noticed it was low when I returned to the lot from shopping. Used the little compressor and drove it home. no problem. Gotta plug it again. This is the second time. :nonod: Haven't parked in the same same lot since I got the last one. Never got a nail in anything else I have owned. WTF? :skep: Corvette tires are nail magnets. :mad
Old Dec 23, 2002 | 12:43 PM
Z06NIN's Avatar
Z06NIN
Default Re: Flat tire in a Z06 (Fast Lane)
:iagree:
agreed.. I have gotten 3 nails in two years....
To Flat tire in a Z06
