Do C8 wheels fit a C5???
Old Aug 17, 2021 | 07:12 AM
JimInPA's Avatar
JimInPA
Default Do C8 wheels fit a C5???
I see a lot of stock C8 wheels for sale. Has anyone tried them on a C5? If so, any photos?
Tnx
Old Aug 17, 2021 | 07:20 AM
Stingroo's Avatar
Stingroo
St. Jude Donor '20-'21-'22-'23-'24
Its been done, but they don't directly bolt on. You either need adapters or to machine the center bore of the wheel to the larger C5/6/7 bore.
Old Aug 17, 2021 | 09:30 AM
djohn3853's Avatar
djohn3853
St. Jude Donor '21
I thought the bolt pattern was also different.
Old Aug 17, 2021 | 09:42 AM
Kubs's Avatar
Kubs
2024 C5 of the Year Winner - Modified
2023 C5 of the Year Finalist - Modified
St. Jude Donor '09-'10-'11
The bolt pattern is 5x120 vs 5x120.65 on the C5. In addition to the hub bore that was mentioned, the C8 used 14mm studs vs 12mm studs. I dont think the 12mm lug nuts will fit right on the wheel.
Old Aug 17, 2021 | 10:02 AM
JimInPA's Avatar
JimInPA
Stingroo, DJohn, and Kubs,
Thanks for the fast response and info.
I'll consider something else.
Tnx,
Jim
Old Aug 17, 2021 | 10:05 AM
smitty2919's Avatar
smitty2919
Hopefully not since they are a terrible design.
Old Aug 17, 2021 | 10:10 AM
acroy's Avatar
acroy
I was thinking the same...
Old Aug 17, 2021 | 01:13 PM
USAZR1's Avatar
USAZR1
Contrary to the above posts, installing C8 wheels isn't that difficult. https://www.corvetteforum.com/forums...s-on-c5-2.html
Old Aug 17, 2021 | 02:01 PM
smitty2919's Avatar
smitty2919
Now why did you go and do that....allowing this tomfoolery to continue. Bugh.
Old Aug 17, 2021 | 04:46 PM
WalterSobchak's Avatar
WalterSobchak
Sad thing is the 5 spoke look better on the C5. Both sets of C8Z wheels are fantastic and GM can't give the Stingray a good option.
Old Aug 17, 2021 | 06:19 PM
USAZR1's Avatar
USAZR1
So, not being satisfied with the present lineup of cookie-cutter wheels and wanting to expand one's options, is tomfoolery? lol
Old Aug 17, 2021 | 07:37 PM
smitty2919's Avatar
smitty2919
AHAHA no, tomfoolery using ugly C8 wheels.
I'm half kidding causing a fuss. Not my car not my problem, but C8 wheels are still ugly lol
Old Aug 19, 2021 | 07:23 PM
pauly1119's Avatar
pauly1119
St. Jude Donor '06-'11
Exactly what I was thinking, thats the only thing I don't like about the C8's. Probably why you see so many sets for sale.
Old Aug 19, 2021 | 09:56 PM
USAZR1's Avatar
USAZR1
I know most of us don't like the oem C8 wheels but here's something to keep in mind when used aftermarket wheels for that car start showing up in the classifieds. C8 wheels are a closer fit to C5's, than a C6 or C7, in that only a set of small spacers will be needed for fitment.
Old Aug 31, 2021 | 07:54 PM
USAZR1's Avatar
USAZR1
Found these photos of a C6 with C8 wheels, today, here in the Austin area.
Old Aug 31, 2021 | 08:14 PM
Stingroo's Avatar
Stingroo
Looks better, and downright good, IMO, on the more angular C6.
To Do C8 wheels fit a C5???
