Shocks/struts
Old Aug 29, 2021 | 01:28 PM
1powdercoater's Avatar
1powdercoater
Default Shocks/struts
Hello, Should I replace my original struts on my 2002 Zo6. It has 41K miles. Thanks
Old Aug 29, 2021 | 02:04 PM
Yello95's Avatar
Yello95
St. Jude Donor '11
20 year old shocks...It won't hurt...i replaced my shocks at around 45K and it now handles much better especially with the C6Z06 shocks...
Old Aug 29, 2021 | 02:53 PM
1powdercoater
TY I had heard to use the C6 struts a few years ago. I was thinking of coil overs but just dont think I need them .
Old Aug 29, 2021 | 04:03 PM
The C5 uses shocks, not struts. Due to the age of the car, I would go ahead and replace them - get some C6 Z06 shocks.
Old Aug 29, 2021 | 07:26 PM
4XLR8N's Avatar
4XLR8N
Pro Mechanic
Old Aug 29, 2021 | 08:34 PM
Yello95's Avatar
Yello95
St. Jude Donor '11
I think you basically knew that they are shocks but just use the term struts...both shocks and struts serve the same purpose.....stabilization....you will not need coilovers because the C6 Z06 shocks do an excellent job at stabilizing your Vette...you won't be disappointed...you can get them from Rock Auto at good prices...email me Directly at kennyusa@att.net if you have any questions you want to ask and have some privacy...
Old Aug 30, 2021 | 09:12 AM
Gordy M's Avatar
Gordy M
For normal driving of a Corvette, the C6Z is a good, economical shock to use, if you were into autocrossing, HPDE, etc there are better ones to use.
Old Aug 30, 2021 | 09:22 AM
acroy's Avatar
acroy
Yes - DRM's Bilstein's
Old Aug 30, 2021 | 10:32 AM
MWWarlord's Avatar
MWWarlord
St. Jude Donor '21-'22
I agree that swapping out for C6 Z06 shocks would be a good idea. You might want to consider swapping out your sway bars for C6 Z06 sway bars at the same time. These two together will really improve your handling without breaking the bank. I agree that given what you do with the car that coilovers would be an unnecessary expense.
Old Aug 30, 2021 | 11:02 AM
Yello95's Avatar
Yello95
St. Jude Donor '11
or maybe C6 Z51 sway bars...
Old Aug 30, 2021 | 03:56 PM
Iceman60467's Avatar
Iceman60467
So should I replace old shocks and sway bar with factory one or something from RockAuto website?
If from RA, which one ???
Thank you
Old Aug 14, 2024 | 04:53 PM
Keyman57's Avatar
Keyman57
Default kit to disable F45 system C5 with C6 06 shocks?
What kit did you use when you replaced C5 with C6 z06 shocks? Rear. Front is F45 new.
Old Aug 14, 2024 | 06:17 PM
DanielW's Avatar
DanielW
St. Jude Donor '04-'05-'06-'07-'08
Are these the regular OEM Z06 shocks?
To Shocks/struts
