LED for front blinking lights on 2002
Old Sep 6, 2021 | 09:05 PM
rat123's Avatar
rat123
Default LED for front blinking lights on 2002
Hi
I would like to replace my 4157A with LED. Which ones should I get. Please give me the part number. Looking for plug a play
Old Sep 6, 2021 | 09:11 PM
Stingroo's Avatar
Stingroo
St. Jude Donor '20-'21-'22-'23-'24
Get a hyperflash harness:
Amazon Amazon
And a set of these:
Amazon Amazon
There are cheaper bulbs out there, but these I've found to be pretty consistently good.
Old Sep 6, 2021 | 09:18 PM
rat123's Avatar
rat123
Amazon Amazon
And a set of these:
Amazon Amazon
Are there LED without using hyperflash harness. Where do you put harness
Old Sep 6, 2021 | 09:19 PM
Stingroo's Avatar
Stingroo
No. LEDs have lower resistance and will cause the bulbs to flash much faster. It installs under the dash in just about 10 mins. Bonus: it will also prevent your hazard switch from failing, which is very common on these cars.
To be clear, your lights will still work, they will just blink extra fast and look/sound like you have a turn signal out at all times.
Old Sep 7, 2021 | 06:21 AM
There are a number of forum vendors that sell LED lights - you might want to touch base with them to see what is available and recommended.
Old Sep 7, 2021 | 05:11 PM
rat123's Avatar
rat123
will lasfit LED work on my 2002 corvette
Old Sep 7, 2021 | 05:47 PM
Stingroo's Avatar
Stingroo
The brand is pretty much irrelevant, but most of those cheaper Chinese LEDs are a crap shoot. You will still need the hyperflash module if you don't want them to look silly in use.
Old Sep 9, 2021 | 08:38 AM
rat123's Avatar
rat123
So the best way to use LED bulbs is using a hyperflash harness
Old Sep 9, 2021 | 08:46 AM
Autoeng's Avatar
Autoeng
Yes
Old Sep 9, 2021 | 09:21 AM
MWWarlord's Avatar
MWWarlord
St. Jude Donor '21-'22
YES. If you want to use LEDs you need a hyperflash harness. They don't cost much, and they really are easy to install.
Old Sep 9, 2021 | 09:58 PM
K9Leader's Avatar
K9Leader
I second going with the Sylvania LEDs for the blinkers. I put some no-name via Amazon LED front blinkers on my '99 a few years ago, used a hyperflash harness, and all was good. Until . . . I also put LEDs on the taillights and all sorts of weird electrical stuff happened - dash lights flashing, staying on, alarm/horn going off when using fob to lock/unlock car, etc. Tried lots of different solutions, including wiring in load resistors on the taillights, thinking maybe the hyperflash harness couldn't handle the front and rear LEDs. Finally solved the problem when I replaced the front blinkers LEDs with the Sylvanias and, miracle of miracles, everything returned to normal.
Which brings up the point that you can use load resistors instead of a hyperflash harness. The load resistors provide the resistance the LEDs don't so that there is no hyperflash. However, they get really hot and you are not using significantly less energy that are one of the benefits of LEDs. Plus they have to be wired in. The hyperflash harness is a much easier and effective solution.
Old Sep 10, 2021 | 12:57 AM
roegs's Avatar
roegs
Seems like all the LED replacements are brighter than the standard incandescent bulbs. Are there any LED replacements that are the same brightness as the standard bulb?
Old Sep 10, 2021 | 07:18 AM
Stingroo's Avatar
Stingroo
Doubtful. Why wouldn't you want the brighter bulb? That's the main reason to make the switch.
Old Sep 10, 2021 | 09:08 AM
TheRadioFlyer's Avatar
TheRadioFlyer
Supporting Vendor
We have an LED bulb / Hyperflash Harness combo package.
https://sharplightinnovations.com/sh...perflash-combo
Most "amber" LEDs today are actually white LEDs with an orange coating instead of the normal yellow This results in a yellow-ish color. Our Amber LEDs are true amber LED (not yellow) are as close to factory color and output you can get.
Old Sep 10, 2021 | 09:13 AM
roegs's Avatar
roegs
My main reason for switching to LED’s would be less heat from DRL’s. I like the DRL lamp brightness as it is and would like to avoid lens replacement down the road.
Old Sep 10, 2021 | 09:18 AM
rat123's Avatar
rat123
Hi
Are you in USA. I'm from Canada
What would it cost me with duty etc
Old Sep 10, 2021 | 09:49 AM
TheRadioFlyer
Supporting Vendor
Hi
I am in USA. I'm not familiar with specific duty costs, but they should be minimal on this item.
To LED for front blinking lights on 2002
Old Sep 10, 2021 | 10:07 PM
roegs's Avatar
roegs
The ordering site give three options for bulbs. White, Switchback, and Amber. Is the video the Amber version?
Old Sep 11, 2021 | 01:10 PM
TheRadioFlyer
Supporting Vendor
This video is of the amber version
Old Sep 19, 2021 | 02:42 PM
c5BlackBeauty's Avatar
c5BlackBeauty
Lifetime Member
St. Jude Donor '05, '12-'13, '15-'16, '21
Can’t go wrong in dealing with Radio Flyer. Excellent knowledge and skills’. Wide variety of lighting options and great customer service.
