A differential brace will help some. You'll never get rid of all drivetrain parasitic loss. You're going to want a diff brace anyway with the power levels that you're looking to have.
Any time you turn power, physics enters the equation, and power in the new direction will be less. On our cars, the power is delivered front to rear through the diff pinion. The power is then turned 90° thru the ring gear. It's lost motion, plus frictional losses. This is why a front wheel drive car gets better mileage and delivers more whp, all else equal, compared to a front engine/rear wheel drive layout. In the FWD layout, power is never turned, except when the drive axles have been pushed all the way to the suspensions limits of travel, which shouldn't be often, lol. If we could put our LS motors in the rear, and mount them in a transverse way, whp would go up dramatically.......
Drivetrain losses are pretty much set from the factory. In order to change drivetrain loss you need to decrease friction in the engine block between the pistons, rods, cylinder walls, transmission gears, rear gears, etc. You would need to rebuild the whole engine and drivetrain.
If you're talking reducing drivetrain inertia then you can go with lighter pulleys, electric water pump, aluminum fly wheel, carbon fiber or aluminium driveshaft (instead of torque tube), lighter wheels and tires, lighter brake assemblies etc..
As mentioned above, lightness and stiffness is usually the way to do it. A light clutch assembly, carbon fiber prob shaft, aluminum couplers, that would do some work for you. And yes, under-driving your accessories will give you a few smidgens of horsepower too.
Unless you have very specific requirements this is not an avenue worth pursuing.
Yatzee! I added electric water pump to my list above.
I had to change mine out because the bell on on my GM pump cracked and got ripped off by the procharger belt. (2nd time in ECS history they've seen this happen. Of course I was that second time).
I wouldn't have proactively made that change though. $800 for a meziere pump would not have been proactively done as a power booster.
