How to clean convertible window?
Old Sep 12, 2021 | 08:56 PM
Alley Oop's Avatar
Alley Oop
Default How to clean convertible window?
What approach do you use to clean the convertible window, both the interior and exterior?
Thanks in advance.
Cheers,
Mark
Old Sep 12, 2021 | 09:25 PM
wdcraig's Avatar
wdcraig
I use a damp (just water) microfiber cloth, followed by a dry microfiber cloth. Be very gentle when cleaning (don't press too hard)- particularly if the top is original to your car, the windows are starting to come unglued. Ask me how I know. . . .(mine came unglued on my 17 years old top and I replaced the top. The owner of the trim shop said he was seeing a lot of C5 convertibles coming in so I was not alone)..
Old Sep 12, 2021 | 10:01 PM
Yes, good idea not to use a lot of force when wiping the rear window on a vert.
Old Sep 12, 2021 | 10:11 PM
Alley Oop's Avatar
Alley Oop
Thanks guys. I don't know if the top is original, but it looks like almost new.
Cheers,
Mark
Old Sep 13, 2021 | 01:07 PM
MWWarlord's Avatar
MWWarlord
St. Jude Donor '21-'22
I also had to replace my top because the window came out. The new top has a lifetime warranty on the rear window. I use invisible glass glass cleaner on a paper towel to clean all the glass including the rear window. You do want to be careful though.
Old Sep 13, 2021 | 02:40 PM
rrwirsi's Avatar
rrwirsi
I repaired my original top window 2 times in the 7 years of ownership. When I clean the outside, I now stuff a king pillow against the inside of the window hoping not to do the repair the third time.
Old Sep 13, 2021 | 04:08 PM
TCFS's Avatar
TCFS
2021 C5 of the Year Finalist - Unmodified
When I wash the car, I start with the shampoo on a sponge and do the glass area, front, sides and rear. As other said, with low pressure to keep the glass on 🤞🏼. I would suggest that you wash your top and impregnate it first if you did not do it and then wash the glass. Interior i do with a spray for glass or with very hot low dilution of dish soap solution and dry with kitchen paper, which tends to avoid foggy windows.
all the best.
TCFS
Old Sep 13, 2021 | 04:40 PM
strand rider's Avatar
strand rider
I avoid cleaners which might be hard on the cloth material, like glass cleaners with ammonia, but other than using care around the defroster wires, that is about it.
Old Sep 13, 2021 | 07:39 PM
Alley Oop's Avatar
Alley Oop
Thanks strand rider.
Cheers,
Mark
Old Sep 13, 2021 | 07:42 PM
Alley Oop's Avatar
Alley Oop
Thanks for the input MWWarlord.
Cheers,
Mark
Old Sep 13, 2021 | 07:44 PM
Alley Oop's Avatar
Alley Oop
Thanks rrwirsi, I'm going to give that a try.
Cheers,
Mark
To How to clean convertible window?
