switchback front corner lights
Old Oct 21, 2021 | 03:38 PM
bc6152's Avatar
bc6152
Default switchback front corner lights
I want to change the front corner lights to switchbacks. I would like to buy from one of our forum vendors and am asking for recommendations from those of you that have done it.
Online I see them priced from $25.00 on Ebay up to $99.99 from various companies. I would have to get them installed as I can't DIY...
TIA...
Old Oct 21, 2021 | 04:02 PM
MWWarlord's Avatar
MWWarlord
St. Jude Donor '21-'22
Sharp Light Innovations. That's where I got mine and I LOVE THEM!!! They are also a forum vendor with top notch customer service.
Old Oct 21, 2021 | 06:32 PM
Sharp Light Innovations is a good source, as is JW Motoring. Also check out Diode Dynamics and Vette Lights.
Old Oct 21, 2021 | 06:45 PM
03 Owner's Avatar
03 Owner
I bought my switch back lights and housings, rear halo tail lights and hyperflash harness from JW Motorsports. Great service and communication.
Old Oct 21, 2021 | 10:50 PM
Ed Ramberger's Avatar
Ed Ramberger
No brainer easy install
Bulbs that work great https://www.ebay.com/itm/302338278773
Thread showing bulbs in my car (with smoked lenses) https://www.corvetteforum.com/forums...al-lenses.html
Old Oct 21, 2021 | 11:27 PM
MrMcE's Avatar
MrMcE
Do the switchbacks go amber/off during turn signal or do they go amber/white?
Old Oct 21, 2021 | 11:40 PM
Ed Ramberger
amber/off
Old Oct 22, 2021 | 12:22 AM
MrMcE's Avatar
MrMcE
Originally Posted by Ed Ramberger
amber/off
That's good, I thought I had seen someone's vid where it went amber/white and that turned me off of switchbacks.
Old Oct 22, 2021 | 01:25 AM
jdmvette's Avatar
jdmvette
Night Owl for life
^ the G1 switchbacks used to do that but the later versions all went to the proper flashing style
Old Oct 22, 2021 | 03:49 PM
bc6152's Avatar
bc6152
amber/off
Ed or anyone else that has this switchback setup please help me out by explaining the sequence of the switchback lighting as I'm a little confused.
1. With lights turned off but car running, only the front amber lights illuminate.
2. With lights turned on car running or not, both side marker (amber lens) and front amber lights (bulb) illuminate.
3. When using turn signals with the car running and lights off only the front amber lights (bulb) will blink.
So if I buy a totally clear lens the side marker will be white instead of amber and the switchback LED will flash amber when turn signal is used and remain white when turn signal is off?
You said "amber/off" and that's where I'm confused. Does off mean no light? Or would the front (turn signal) switchback bulb be white vs. amber when turn signal is not being used... Whew! Thanks for taking the time to explain this as it is greatly appreciated. BC
Old Oct 22, 2021 | 04:06 PM
03 Owner's Avatar
03 Owner
Mine function like this.
Running lights always amber.
Parking lights or head lights on white.
Turn signals always flash amber after turn signal is shut off they go back to white when parking or headlights are on. I do not have any white in turn signal use only amber.
I have clear housings and because Oregon requires front side marker to be amber I used an amber led side marker light. It looks good through clear lense.
Old Oct 22, 2021 | 04:43 PM
MrMcE's Avatar
MrMcE
Light switch in off position, side markers (peanut 194 bulbs) are off, the forward facing switchback LED spot is the DRL and always on while driving. It'll be solid white if you have switchbacks. During turn signal, it will either blink between amber/off or blink between amber/white depending on which bulb you buy.
Light switch in second position just turns on side markers and tail light running glow, everything else is the same as above.
Light switch in third position just turns on headlights on top of everything else above.
The color of your side marker depends on your housing lens and/or the bulb color. If you have a clear lens but also a white peanut bulb, it'll be white.
If you want the DRLs to be solid amber while driving and blinking amber for turn signal, you wouldn't get a switchback bulb.
Old Oct 22, 2021 | 05:42 PM
Ed Ramberger
With the bulbs I have and posted:
With the lights off, the daytime running lights are yellow.
When I turn on the lights (parking or full) the daytime running lights turn white.
The lens is not relevant to the color. I purchased Depo smoked lenses with black trim
When the blinker is on, the blinking side is amber/off and the other side stays white (just like most all new cars with LED blinkers)
For the 194 side marker bulb, you will buy an amber led bulb.
Old Oct 22, 2021 | 05:47 PM
MrMcE's Avatar
MrMcE
Ah I didn't know lights off meant DRLs were yellow instead of white for those switchbacks. Doesn't make sense to me how that works, as if the stock bulb setup was to have 2 brightnesses of DRL.
Old Oct 31, 2021 | 09:14 PM
Lil Blue Coupe's Avatar
Lil Blue Coupe
hey guys, so if I were to pick up these items would I need anything else, am I overlooking anything?
Turn Signal Lens
1997-2004 Chevrolet Corvette Driver + Passenger Replacement Bumper Signal Parking Lights Lamps Pair 1997-2004 Chevrolet Corvette Driver + Passenger Replacement Bumper Signal Parking Lights Lamps Pair
$53
Hyperflash Harness
Corvette Envy C5 Corvette Hyper Flash Fix/Signal Fix/LED Bypass Hyper Flash Harness Corvette Envy C5 Corvette Hyper Flash Fix/Signal Fix/LED Bypass Hyper Flash Harness
$46.50
DRL LEDs
2X Dual Colors 3157 4157NA LED Switchback White Yellow Turn Signal Light Bulbs
$19
Old Oct 31, 2021 | 11:08 PM
jdmvette's Avatar
jdmvette
Night Owl for life
^ I think the black housing lenses look better but yeah, that's it
Old Oct 31, 2021 | 11:56 PM
Lil Blue Coupe
thanks for the reply... I actually foresee a set of the black ones in the future, just wanted something I am sure I'd like first. I think once I see a black set in person it will change my mind
Old Nov 1, 2021 | 06:22 AM
LWSZ06's Avatar
LWSZ06
The DRLs and the Turn signals are both on the same (Amber) filament. The Park Lights are on the White Filament. When you turn on the Park Lights, they turn the DRLs Off. Most all of the lights are controlled from the BCM.
Old Nov 1, 2021 | 09:11 PM
Ed Ramberger
To switchback front corner lights
