Water on driver's side floor
Old Oct 27, 2021 | 12:30 PM
billla's Avatar
billla
St. Jude Donor '14
Default Water on passenger side floor
I've done all the checks from the excellent FAQ thread, but I'm still getting a wet passenger-side floor.
My driveway slopes downward significantly, so the car is nose-down a fair bit when parked - could this be the issue? Would I be better off to back in and be nose-high?
Thanks!
Old Oct 27, 2021 | 12:37 PM
Mikado463's Avatar
Mikado463
Ok, your title says driver side but post says passenger side ?
Regardless, I'd get a volunteer, sit inside and let them soak you with a hose and perhaps you can pinpoint the leak
Old Oct 27, 2021 | 12:39 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
Your cowl “udders” are clean ??
Old Oct 27, 2021 | 12:48 PM
MWWarlord's Avatar
MWWarlord
St. Jude Donor '21-'22
Good suggestions above. Clogged "udders" are the main cause of this. Make sure you have dielectric grease on all the weather strips. If you have a convertible, make sure that the rear window is not leaking. This can be a common issue as well. If needed, the windows and convertible top can both be adjusted.
Frank4202's Avatar
Frank4202
Clean your udders under the hood. Lots of youtube videos on how to do this. If they are clean, some kind of weather-stripping is probably worn causing the leak. Id have the wife soak the car with a garden hose and while Im inside looking for the leak.
Old Oct 27, 2021 | 02:17 PM
Russco's Avatar
Russco
My 2000 Vert is getting wet on the pass side too. I believe it’s the condensation from the A/C not draining and backing up into the blower area and dripping out from there. I haven’t had a chance to confirm this but I’m pretty sure that’s what it is since it hasn’t been out in the rain or washed lately. My wife felt it dripping during turns at speed.
Old Oct 27, 2021 | 03:27 PM
billla's Avatar
billla
St. Jude Donor '14
Apologies; passenger side.
Yep, been through the FAQ and cleaned out the cowl and the udders, and made sure they were correctly reconnected. I'm about 99% sure that it's not coming from there.
Old Oct 27, 2021 | 05:12 PM
novasscnc's Avatar
novasscnc
On wheeler Dealers they looked for a leak used a smoke machine on the inside it showed the leak
Old Oct 27, 2021 | 05:49 PM
ttiros's Avatar
ttiros
Went through this last year. A/C drain vent was clogged.
To Water on driver's side floor
