voltage drop when not in use.
Old Nov 14, 2021 | 08:42 PM
captnorm's Avatar
captnorm
Cruising
Default voltage drop when not in use.
My 03 battery looses voltage when not in use. In 3 days it drops to about 8 volts. As far as I can tell everything is turned off. No voltage loss if battery is disconnected.
Old Nov 14, 2021 | 08:51 PM
jdmvette's Avatar
jdmvette
Night Owl for life
Something parasitic is obviously killing it and fast.
Old Nov 14, 2021 | 09:07 PM
Alley Oop's Avatar
Alley Oop
I got this from another post...If you do have a voltage drop, check on the charging system. You should see approximately these…0.18 volts on the positive side and 0.10 on the negative.
Old Nov 14, 2021 | 09:14 PM
GettnBetter's Avatar
GettnBetter
A standard wet battery is intended to last 2-5 years. How old is the battery?
Old Nov 15, 2021 | 02:10 PM
galyon_j's Avatar
galyon_j
On a C5? Surely you jest.
Old Nov 15, 2021 | 02:37 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
If your battery keeps discharging like that even if you find the cause of the parasitic draw you’ll most likely have to replace that battery !!…don’t know if you have any electrical skills and maybe own a DVOM but maybe this video may help !!..and I’d get your battery tested also…it may not be holding a charge and a battery less than 11.90 volts is dead.
Old Nov 15, 2021 | 03:43 PM
1wholikescars's Avatar
1wholikescars
If you don't have a meter, and you can let the car go while you try things, you can pull fuses and see if it stops, that would tell you which things to look at.
So, for example, when I have had to do this in the past on a car with a mysterious draw, I pull about half the fuses. Then check the battery to see if it's holding. If it's not holding, I at least know it's the half that is left, so I put the original half of the fuses back, and then pull half of the half that was left to see if I have narrowed it down further. Basically, just keep taking out half until you narrow it down to the one or two left.
In my case, it was really obvious once I found it, the cigarette lighter was always on, and I had my charger plugged into it and it was drawing all the time. I rewired that to an ignition only fuse and that fixed my issue.
But the above it quite good if you have a meter and some time as well.
To voltage drop when not in use.
