Driver's Side Door Controls - Back Light
Old Nov 15, 2021 | 12:08 PM
Bill.Moore's Avatar
Bill.Moore
Cruising
Default Driver's Side Door Controls - Back Light
Hi - new C5 owner - owned several C3 before. Two questions - 1st question - noticed last evening that the driver's side door the back lights for the locks, window controls are out. The passenger side work fine. Any suggestion on best places to start? Before I dig in, is this all one unit or separate for each window and lock? 2nd question - the center console only opens about 45 degrees rather than full 90? Is my hinge or top broken or is 45 degrees normal opening width? Watched several youtube videos etc but can't see a good video or photo of "normal" operation.
Thanks in advance
1998 C5
Bill
Old Nov 15, 2021 | 12:22 PM
MrMcE's Avatar
MrMcE
For the center console- as you open it, pull it toward you
Old Nov 15, 2021 | 12:25 PM
MWWarlord's Avatar
MWWarlord
St. Jude Donor '21-'22
Welcome to the forum, and congrats on your C5! The center console has sort of a compound hinge. It threw me off too. after you open it, pull up on the console hatch and it will open fully. There are several options for the door switch lights. If you check eBay, you'll find lots of aftermarket LED options.
I hope you have lots of fun with your car. Don't forget to SAVE THE WAVE!
Old Nov 15, 2021 | 12:32 PM
Bill.Moore's Avatar
Bill.Moore
Cruising
Thank you - I will give that a try for the center console - see if that helps. Will search eBay for some options - sounds like the door units may be need to be replaced!
Bill
To Driver's Side Door Controls - Back Light
