lowering C5
Old Nov 23, 2021 | 08:57 PM
vxk's Avatar
vxk
5th Gear
Default lowering C5
I have a C5. I lowered the car all the way around with Eibach lowering bolts. The rear is fine the way it sits. But i am looking for some help on the front. I am currently running 255/30/19 tire and like the way that tire looks on the rim. But i need to lower the front another 1/2 to 3/4 of an inch. Does anyone have any advise on what else i can do to go just a little lower, without having to go with bags or coilovers?
Old Nov 23, 2021 | 09:08 PM
MrMcE's Avatar
MrMcE
Have you given the front a few days time to settle down?
19's up front might need 275/30's as I've seen in other cars that have very minimal wheel gap
Old Nov 23, 2021 | 09:25 PM
vxk's Avatar
vxk
5th Gear
I did let it settle and it has probably been about 3 months and put about 500 miles on it since. Ya, i don't think it will go down anymore, i really wish it did settle the 1/2 that i would like to have. Thank you for the reply
Old Nov 23, 2021 | 09:54 PM
PerryKing's Avatar
PerryKing
2020 C6 of the Year Finalist - Modified
How far off the ground is the front air dam? I don’t think I’m all the way down on the VMS lowering bolts I installed and mine’s at 2”.
Old Nov 23, 2021 | 10:10 PM
mstromquist's Avatar
mstromquist
2015 C5 of the Year Winner
If you can get to the bottom of the front adjusters they have a stack of rubber glued to them. I took my spring completely out and cut the rubber off. It made a big difference. They also sell bolts that have the plastic spacer on them. If you cut the rubber off, leave a little on the bolt so it won't chew into the spring. I've since gone to coilovers and am happy with them so far.
Old Nov 23, 2021 | 11:54 PM
vxk's Avatar
vxk
5th Gear
MrMce... not to change the subject, but what kind of taillight are in your profile photo?
Old Nov 23, 2021 | 11:55 PM
vxk's Avatar
vxk
5th Gear
PeerryKing, I am also about 2" left on the front air dam, but i have no more turns on the lowing bolts.
Old Nov 23, 2021 | 11:57 PM
~Josh's Avatar
~Josh
Banned Scam/Spammer
Even if you took the front bolt out and lowered the rear fully, the front will always be higher, not a good look.
Coilovers are the answer.
with the rear lowered on stock bolts when you hit dips in the road you’ll experience a trampoline effect in the rear suspension. The rear leaf is under little tension fully lowered and when compressed it discharges past zero and bounces until the force dissipates.
Although lowering a c5 is free, to be done properly costs $1200-$3400.
Old Nov 24, 2021 | 12:03 AM
vxk's Avatar
vxk
5th Gear
Thank you for the info. I might have to try removing the rubber. When you cut the rubber off of the springs. What kind of ride did you get? currently my ride in actually pretty good. That is why i would like to get that 1/2 inch or so. And i am trying not to spend the money for those coilovers, because i only need that 1/2 to 3/4 more. But i know the coilovers would be the best way, without a question.
Old Nov 24, 2021 | 10:55 AM
MWWarlord's Avatar
MWWarlord
St. Jude Donor '21-'22
Yup, coilovers are the correct answer. If you want the car to be that low, pay the money to do it right.
Old Nov 24, 2021 | 11:39 AM
MrMcE's Avatar
MrMcE
They are the standard unmodified led taillights a ton of c5 owners have, except I modified just my inner ones by myself to be halo only style on driving light mode. Anyone buying sets will get all 4 in the same style (either unmodified like my outers, or all modified like my inners). They all light up fully on braking.
Old Nov 26, 2021 | 10:28 PM
mstromquist
Keep in mind, the lower you go with the stock suspension the worse your ride will be.
To lowering C5
