Hood Liner
Old Nov 27, 2021 | 07:02 PM
LM7's Avatar
LM7
4th Gear
Default Hood Liner
Is they're anyone that does NOT have a hood Liner. And if so have not having it caused any issues.
Old Nov 27, 2021 | 07:07 PM
Stingroo's Avatar
Stingroo
St. Jude Donor '20-'21-'22-'23-'24
I don't. Haven't had one since I put my trackspec vents on. Doesn't do anything but act as a fire blanket anyway, really.
Old Nov 28, 2021 | 08:36 AM
Toys4Life C5's Avatar
Toys4Life C5
St. Jude Donor '21
I believe it also helps keep the hood cooler from engine heat - over years of keeping the paint cooler it may extend its life. Also, is deadens sound from the engine a bit. I would leave it on unless yours is in nasty shape. You can still get a new one. Just my 2 cents!
Old Nov 28, 2021 | 12:10 PM
Fastclient's Avatar
Fastclient
My liner was looking a bit tacky so I contacted my local dealership. Sure enough he could get one. Said it would need to be prepaid and there would be no returns. When I bought a liner for my C3 it came in a small box and folded. When installed you could see all the creases. I asked the parts guy if this was the case with the C5 liner or if it was torn etc. could I return it then? He replied In a very stern voice "I said no returns!" Customer service at it's finest.
Old Nov 28, 2021 | 12:13 PM
Stingroo's Avatar
Stingroo
Special order parts are generally not returnable. Not really relevant to the thread, but a fact of life.
Old Nov 28, 2021 | 12:33 PM
knewblewkorvette's Avatar
knewblewkorvette
Two of my C5s have no headliner. No problems at all running them without.
Old Nov 28, 2021 | 12:48 PM
Toys4Life C5
St. Jude Donor '21
There are some good dealerships out there but is really is like some of them do not want your business... There are ways of saying no without being an ars.
Old Nov 28, 2021 | 01:47 PM
c5arlen's Avatar
c5arlen
Some people are just rude... Bad Parenting is not reserved for service writers....Happens everywhere, except perhaps a mortuary.
Old Nov 28, 2021 | 04:47 PM
When I had a custom hood on my 2000, I was not able to run a hood liner on the car. Did not cause any problems at all.
Old Nov 28, 2021 | 04:49 PM
Stingroo's Avatar
Stingroo
Yeah good point - lots of people do custom paint on their hoods and such, too.
I'd be shocked if anyone ever truly had paint issues from not running a liner.
Old Nov 29, 2021 | 03:11 AM
vette4fl's Avatar
vette4fl
Go commando!
Old Nov 29, 2021 | 04:17 AM
Yello95's Avatar
Yello95
St. Jude Donor '11
Default hood liner
I have a Carbon Fiber hood and it does not allow for a hood liner....there is no requirement for a hood liner.....
Old Nov 29, 2021 | 01:37 PM
MWWarlord's Avatar
MWWarlord
St. Jude Donor '21-'22
The underside of my hood (under the hood liner) did not look good. As long as it isn't torn, you can refresh your OEM liner by spraying it with some black Krylon grill paint.
Old Nov 29, 2021 | 02:21 PM
Stingroo's Avatar
Stingroo
Yeah the underside of mine also looks like crap. I should spray it black this weekend. Might be a good project.
Old Nov 29, 2021 | 03:39 PM
MWWarlord's Avatar
MWWarlord
Make sure you mask off those vents really well before you do.
To Hood Liner
