C5 corvette cam options?
HTH.
Don't forget to SAVE THE WAVE!
A more aggressive cam may require a higher RPM at idle to stay running. The stock convertor has a very low stall for the purpose of efficiency, but with the faster idle of the new cam, the car may want to creep at a stop, and will start to hook up power before the new cams power curve.
A higher stall converter, let’s say 2500 for a street driver, will allow the engine to idle faster before engaging power, plus it allows the engine to reach the power curve with less restriction. Kind of like slipping the clutch would do.
So the higher stall provides better street driveability and also allows the new cam to be more effective. However, this stall has the downside of being less efficient when pulling out from a stop under normal driving conditions, although you may hardly feel the difference, if at all. In addition, more aggressive cams, while good at delivering more fuel air mixture, also degrade your MPG.
My advice is ignore the efficiency aspects, get the cam and higher stall converter, and have fun!
These changes alone will really wake up the car and you may decide you don’t need a cam. Just be conservative with the stall speed, and don’t let anyone talk you into something too radical. A 2,000 - 2500 stall is more than adequate for a street cam with a 1400-6000 rpm range. These combinations should be discussed with your dyno tuner and the transmission guy in deciding what you want.
Both the A&A and ECS kits are fairly complete and I think you'd be pretty happy with either one. Provided your engine is healthy and you aren't prone to bouts of wild stupidity, you shouldn't need to do much more than install the kit, get tuned, and start laying down stripes.
I'd recommend you call A&A and have a conversation with them. Tell them what you're working with (current modifications, history of the engine, all that good stuff) and what kind of end result you want, and ask them what they think you might benefit by doing in terms of supporting/additional modifications based on that information.
A set of 3.73s and a mild stall converter wil flat set you back in the seat, yet your engine can be bone stock. A tuner can also adjust shift rpm and firmness in the normal course of the tune. Now you’re into it for maybe three grand(speak up if you think that’s wrong), providing the gears and convertor are done at the same time.
I love the idea of a supercharger, but I also recognize there are other strategies that either cost less, or don’t completely lock you in to a specific course of action. Going with the drivetrain route, you always can add headers later, or a cam further down the road as cash is available.
I have had all the above at one time or another, and there is not a “right” route per se. It really depends on what your near term plans are. For example in my earlier days there was no limit of horsepower, noise, or inconvenience for me.Now, retired at 67 years old, I want a smooth comfortable ride, yet stab it and catch a couple of gears when the coast is clear, so a bit of stealth is called for. So I may want gears, a mid-range cam, headers but not loud mufflers. Think about where your happiness lies, and have lots of fun !!!
Stock bottom end will hold more than enough to kill you. The trans is the crap shoot. The auto could die on stock power. Or it could live forever. There's no real "right" answer to that question in my experience.
600 engine hp is common on supercharged stock motors, and the drivetrain will survive provided they are not beat on out of the hole. This is about the point where traction becomes the limiting factor. The auto trans, or the clutch on the manual are probably the weakest links.
It's the only rabbit hole in the world that even Bugs Bunny can't climb out of!! Only one with snowballs that big too!!
