Condenser/Radiator Screen
Old Dec 13, 2021 | 07:29 PM
ericba's Avatar
ericba
St. Jude Donor '21-'22-'23
Default Condenser/Radiator Screen
Now that I upgraded my radiator to a Trackspec (2-1/2" thick) version (w/ integrated EOC) in hopes of keeping things cool when I'm enjoying HPDE's, I realized that there is no longer room to squeeze my fabricated wand down between the condensor and radiator or between the radiator and fan assembly to blow things out periodically. My only options now are:
  1. Vacuum the front of the condenser or,
  2. Remove the radiator from the car
So based on that conclusion, I decided to fabricate a screen. This is my REV1 and it may be an epic failure however, I have the time so I gave it a shot...
What my condenser/radiator tends to collect are pine needles (PNW), leaves, grass clippings and sand/grit. I figured that I can't stop the sand/grit without restricting airflow however, I should be able to stop the bigger stuff. So this what I did:
Basically, I'm using 1/2" angle and 1/2" flat bar to create a holder for some HD screen door mesh (Time will tell how HD this stuff is). They also sell Pet Proof screen door mesh which is stronger however it appears to be more restrictive (air flow).
After getting everything fit together, I pop riveted the assembly together:
Finally, the installed product:
Like I said, REV1, probably won't know how restrictive it is until summer but it least "looks" like it will work. If this mesh is too restrictive or if it tears too easily, I'm sure I can find a more HD mesh that is a little courser so that will be REV2.
Anyway, I thought I'd share...
Old Dec 14, 2021 | 07:48 AM
wydopnthrtl's Avatar
wydopnthrtl
Excellent thank you
I wonder if you can get a large sheet of "OUTERWEARS" and cover it with that? If so you'd just easily brush anything off in seconds.
Old Dec 14, 2021 | 09:43 AM
ericba's Avatar
ericba
Originally Posted by wydopnthrtl
Excellent thank you
I bet you could find it somewhere...not a bad thought. I am very curious to see how restrictive this mesh is. I'm kind of expecting to have to go with a larger mesh to keep the air flow up but if not, that Outwears stuff would do the trick regarding sand/grit! Outerwears may be my REV3 version now...
Old Dec 14, 2021 | 10:31 AM
knewblewkorvette's Avatar
knewblewkorvette
Wow, that's an awesome job you did there.
Old Dec 14, 2021 | 11:14 AM
MWWarlord's Avatar
MWWarlord
Well done. Looks very clean. I look forward to hearing what impact it has on airflow.
Old Dec 14, 2021 | 11:22 AM
lewislgZ06's Avatar
lewislgZ06
NCM Lifetime Member
St. Jude Donor '18 thru '26
Awesome fabrication work! Hope the results are favorable.
Old Dec 14, 2021 | 03:13 PM
vette4fl's Avatar
vette4fl
This is way over my head, but perhaps an engineer can make sense of it…
https://www.eng-tips.com/viewthread.cfm?qid=168110
Aside from that, I think you’re going to have significant restriction with that fine of a mesh. For example, take a window screen and hold it up against the wind. In a mild breeze you will feel pressure drop. Still, it may provide enough volume for your purpose even so…. You did a nice job on that!
Here’s another screen. it may not be fine enough though.
https://www.corvettepartsandaccessor...adiator-screen
Old Dec 14, 2021 | 03:52 PM
ericba's Avatar
ericba
Yup, I agree that this may be too fine of a mesh however I wanted to start fine and go up from there. The frame I made can be reused with any insert material I want to use. If this is too restrictive, I'll go up to a Mesh Size of 5 (0.157") or maybe 4 (0.187"). And if none of this works, so be it...nothing ventured, nothing gained...
Old Dec 14, 2021 | 05:27 PM
JamesNC's Avatar
JamesNC
Radiator/Condensor cleaning was one of the very first things I did when my car arrived home. I immediately thought of the possibility of some sort screen/mesh to mitigate the debris build up but haven't done anything about it as of yet.
@ericba What you've fashioned is very impressive; I admire the skills you have sir
Old Dec 14, 2021 | 06:20 PM
Nicely done and hopefully it will last a long time.
Old Dec 14, 2021 | 06:38 PM
Mickeyrx70's Avatar
Mickeyrx70
Old Dec 14, 2021 | 11:31 PM
Yello95's Avatar
Yello95
St. Jude Donor '11
You did a great job Eric...you WILL need to change the size screen because of air flow restrictions...trust me...more like the size of holes in the screens on the Z06
This size screen/holes is what i would recommend...
Old Dec 15, 2021 | 12:17 AM
ericba's Avatar
ericba
Thank you and yes, the magical question is air restriction and how much is too much. My concern with starting too large is that all the crap I’m trying to stop, won’t be stopped if too large so what did I gain? If my current size is too small (based on actual measured temperatures), I’ll go up a size…easy, peasy. And I’ll keep going up until I find the sweet spot based on temperatures and not a visual hypothesis.
I’ll definitely update this thread once I have some data but that won’t be for a while since I’m in the middle of Seattle’s monsoon season.
I too am pretty sure I’ll need to go up a size but what do I know? I’m wrong all the time as it is!
Old Dec 15, 2021 | 08:33 AM
Yello95's Avatar
Yello95
St. Jude Donor '11
Originally Posted by ericba
Thank you ......
Good try Eric but...No one makes more mistakes than ME....
Old Dec 15, 2021 | 11:01 AM
mstromquist's Avatar
mstromquist
2015 C5 of the Year Winner
Fabrication looks very good and the frame will work for whatever size you'll need. Nice job.
Old Dec 15, 2021 | 11:14 AM
oh1vette's Avatar
oh1vette
Elite Engineering used make a nice screen for this....similar to yours, but to your point it was a bit curved shape
Old Dec 15, 2021 | 04:41 PM
GroundFlyer's Avatar
GroundFlyer
St. Jude Donor '19
I just used gutter screen from Lowes. It’s good to 90 mph so far. No difference in temps using it. Under $5. No frame needed..the fold seen on the leading edge stiffens it. It comes with the fold already formed. Just cut piece to length.
To Condenser/Radiator Screen
Old Dec 15, 2021 | 08:40 PM
vette4fl's Avatar
vette4fl
I have one sitting in the garage right now; although I was…going to use it for the gutter, this may change my plans!
Good example of old school hot rodding
Old Dec 15, 2021 | 10:54 PM
No-autotrans.'s Avatar
No-autotrans.
I was going to suggest something like this https://www.onlinemetals.com/en/buy/...rforated-sheet
Any size hole or spacing you want, no frame needed.
I have seen Chevrolet emblems, as well as other different shape holes.
Although, that gutter screen idea is pretty cool.
Old Dec 16, 2021 | 04:11 PM
kjchristopher's Avatar
kjchristopher
How did you secure it?
