Default C5 Vs C6 Brake Master Cylinder
Old Dec 24, 2021 | 02:57 AM
drb930's Avatar
drb930
Default Default C5 Vs C6 Brake Master Cylinder
Anyone know what the difference is between the 2?
I know the calipers piston wise are pretty much the same.
Thanks,
Dave
Old Dec 24, 2021 | 07:07 AM
Stingroo's Avatar
Stingroo
St. Jude Donor '20-'21-'22-'23-'24
Calipers are identical except the casting is slightly different which makes the C6 units more rigid.
Can't speak to the master cylinder, though.
Old Dec 24, 2021 | 12:14 PM
drb930's Avatar
drb930
Thanks.
The master cylinders are 2 different part numbers but look the same on the outside.
Old Dec 27, 2021 | 08:50 AM
galyon_j's Avatar
galyon_j
Originally Posted by drb930
Thanks.
This is all I could find. Apparently the reservoir volume and piston diameter are the same for each.
To Default C5 Vs C6 Brake Master Cylinder
