New top for C-5
I have used their product before, they are a long established company that has the capacity to do OEM work. I first used the company long ago when I bought a top out of a sears catalog, when, along with a new top for my car, I also learned to hire the installation out next time, and every time after that.
I also had the common C5 rear window seal fail. Following advice here, I glued the glass back in and was very happy with the completed results. MY top still looks good, but years of the heat expansion and contraction cycle has the seal needing to be redone, so I am replacing the entire top. From the looks of things, I could once again glue the window in, but also know how difficult it will be to get a suitable surface for the glue so that it will stick to the surface it just detached from, so I decided to just it replace after one repair, kind of like I treat kitchen appliances, fix once, replace. I used Rhino glue, and know how those types of adhesives resist gluing on old glue residue. I see below that grinder11 used a dedicated window adhesive, which, had I been aware of, would have used over the thin super glue type stuff recommended in the post I read.
The Robbins web site is very detailed, so much so that a person in the market might gain some product insight by checking it out. In the old days, before they went solely into production, they had the biggest upholstery shop I had ever seen, with multiple, maybe 8-10 work bays, and three or four cars getting tops installed every time I swung by, with the manufacturing done upstairs. .
