[Z06] Bumped a Curb
Old Dec 28, 2002 | 01:54 AM
Scooby Snacks's Avatar
Scooby Snacks
Default Bumped a Curb
at a local drive-thru bank and scratched my rim about 3" long right on the lip of the rim. Has anyone repainted a section of the rim after polishing out the rough area? If so where did you find the paint? Or am I just going to have to live with it until I can buy a new rim?
[Modified by Scooby Snacks, 1:55 AM 12/28/2002]
Old Dec 28, 2002 | 04:04 PM
Zapper's Avatar
Zapper
Default Re: Bumped a Curb (Scooby Snacks)
Depending on how bad the gouge is.....
Z06 Wheel Paint code is WAPB-9789 and is called Grey Metallic by J.B. Fuller Co. I did however, find out that the code number WAPB-9789 is a GM code number and most auto paint stores can make this product. Just got done re-touching my rim using the kit supplied with Ultimate Touch -up Systems. I ended up removing the tire from the rim and lightly sanding the very outside edge of the wheel to remove the light scratches. I masked off just the 3/16" edge with the scratches and sprayed the match provided from Ultimate using an airbrush. After a few coats of silver metallic and a few coats of clear, it looks as good as new. Perfect match! http://www.ultimatetouchup.com has it.
There is a slight difference in paints from 01 to 02 onwards :chevy
Old Dec 28, 2002 | 05:00 PM
C6Cam's Avatar
C6Cam
Default Re: Bumped a Curb (Zapper)
Thanks for the info!
I did the exact same thing as this thread's author- at Burger King. Man was I pissed!
I'll give the ultimate touchup kit a try! :cheers:
Old Dec 28, 2002 | 07:20 PM
Scooby Snacks
Thank you very much for the reply, hopefully I'll have as good as luck as you when I try it.
Thanks Again,
Scooby
To Bumped a Curb
