Anyone know a good way to restore tail lights? I left my original ones outside and are pretty dusty and the back of them looks slightly faded but not from sun damage.
-non of them are cracked and was in pretty good shape until now.
gracias
plastic polish is gentle and will make them sparkle
They're just plastic, getting water in there to clean out dust is fine. Tons of people have takeoffs laying around if you don't think they're worth the effort.
I have cleaned many plastic tailights by putting them in the dishwasher. I take them out before it goes into the "drying" setting just to make sure the don't get exposed to too much heat. Polish them with Meguires PlastX and they will look like new inside and out.
WD40 or Goof Off will remove most any residue. You have to be careful what you use on plastic or you can damage the plastic and it will turn brittle and/or white.
Solvent will remove the sticky. Experiment first to make sure it doesn't react with the plastic. I've used solvent on all sorts of materials, doesn't seem to affect most plastics.
WD-40 worked great! now Its greasy so will try some alcohol .
DO NOT use alcohol on plastic. It can turn it white and also make it very brittle. After you get it clean then put it in the dishwasher and remove before the heat from the drying cycle comes on and let air dry.
But my budget gin comes in a clear plastic bottle and it does fine
