Under hood lighting
Old Jan 29, 2022 | 09:35 PM
MyPython's Avatar
MyPython
Default Under hood lighting
What tells the under hood lights to come on when you lift the hood? Yes, I know where the light is and the connectors, but I want to know what makes it turn on and where?
Old Jan 29, 2022 | 09:49 PM
jcgunn's Avatar
jcgunn
There is a mercury switch and a timer.
Old Jan 29, 2022 | 09:55 PM
jdmvette's Avatar
jdmvette
Night Owl for life
Gravity
Old Jan 30, 2022 | 02:12 AM
MyPython's Avatar
MyPython
Any idea where?
Old Jan 30, 2022 | 03:40 AM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
Any idea where?
There is a Mercury switch in the bulb assembly that was mentioned !!
Old Jan 30, 2022 | 11:24 AM
MyPython's Avatar
MyPython
Thank you very much. Cheers
Old Jan 30, 2022 | 11:37 PM
cool555's Avatar
cool555
Not to hijack the thread. Has anyone replaced the underhood light bulb? My googling hasn't given me any good results.
thanks!
Old Jan 31, 2022 | 12:04 AM
jdmvette's Avatar
jdmvette
Night Owl for life
I rewired mine a long time ago with some spare bolt LEDs I had laying around. Not at all like popping in a bulb but it's pretty bright now
I just ordered a new plastic lense cover, drilled a hole in it and tapped to the positive and negative parts of the switch housing.
Old Jan 31, 2022 | 12:37 AM
Old Jan 31, 2022 | 03:13 AM
MyPython's Avatar
MyPython
thanks!
That is what I was doing. I put in two super bright LED's. It made all the difference in the world.
Old Jan 31, 2022 | 10:02 AM
MWWarlord's Avatar
MWWarlord
St. Jude Donor '21-'22
thanks!
There are plug and play LED options for the stock underhood light. I actually deleted my underhood light to make room for my catch can.
Old Jan 31, 2022 | 04:18 PM
cool555's Avatar
cool555
Whoa I wasn't expecting that LED mod. I need to replace the underhood light and the visor bulbs.
Old Jan 31, 2022 | 06:50 PM
AUandAG's Avatar
AUandAG
Here's another option utilizing a small led panel.
Old Feb 1, 2022 | 12:09 AM
vette4fl's Avatar
vette4fl
This a slightly more powerful version, although there have been reports of excessive heat.
Old Feb 2, 2022 | 05:04 AM
VetteMed's Avatar
VetteMed
I'm not sure it's really a "mercury" switch, I think those were phased out years earlier due to toxicity concerns, but it is an angle-sensitive switch. I've taken the one apart in my 2002 Silverado and there's actually a metal rocker that causes a sliding contact to move when the angle of the hood is past a certain point. I assume the C5 mechanism is similar.
Old Feb 2, 2022 | 02:10 PM
MrMcE's Avatar
MrMcE
Gotta get an led festoon with 90 degree twisted loop contact ends
To Under hood lighting
