Having different tire sizes a bad idea?
Old Feb 15, 2022 | 02:35 PM
Geardownson's Avatar
Geardownson
Default Having different tire sizes a bad idea?
I have a bit of fender gap im not fond of and I was thinking of lowering the stock bolts just a little and maybe going a size up in profile in the back or both. Then lowering more. As of now with the tires the way they are the spedo is correct because I went up in wheel size and down on tire. Will going up on the back throw anything drastic off aside from the speedo? Any electronics affected?
Old Feb 15, 2022 | 02:43 PM
The Former's Avatar
The Former
Banned Scam/Spammer
Whatever you find that's one good looking car. I just went up one size and one size wider resulting the same tire height. You already know all this though. I also tried to move the bolts that control ride height. They wanted to strip so I left it alone. I would like a lower ride height though. I think a shop may have to get involved here on my behalf.
Did you have any difficulty with your bolts?
Old Feb 15, 2022 | 02:44 PM
64drvr's Avatar
64drvr
St. Jude Donor '15
IMO you need to keep the front/rear bias the same as stock to not have incorrect data for the ABS/TC.
Old Feb 15, 2022 | 02:59 PM
Geardownson
I had not tried it yet. I took it to a friend's to do it and he thinks it would be way too low. So I got hesitant. I was just tossing ideas around to possibly get rid of some of the gap. Lowering/bigger tire etc
Thank you for the response. I was thinking it might screw something up electronically. By what your saying it would be best just to go up on profile so they are all the same even though the spedo would be off..
Old Feb 15, 2022 | 03:00 PM
Geardownson
Current tire size is
Front Tire Size: 265/30/19
Rear Tire Size: 295/30/20
Would a 35 series be a huge jump?
Old Feb 15, 2022 | 03:04 PM
64drvr's Avatar
64drvr
St. Jude Donor '15
IIRC, stock tires are 25.5” front and 26.5” rear diameter. If you want a 27.5” rear tire, you will need a ~26.45” front tire (I would think that will rub) to retain the stock bias. Sorry, my technique is to look at actual measured diameter and width in inches; there can often be a variance between what the sidewall says versus the tape measure.
Old Feb 15, 2022 | 03:59 PM
The Former's Avatar
The Former
Banned Scam/Spammer
No. That's what I found anyway. When you move one tire size up or down it really makes zero diff.
I went from 275/40/18 to a 295/35/18 and the tire height was almost exactly the same. However the contact patch with the ground is almost 2 inches wider.
Old Feb 15, 2022 | 05:18 PM
Geardownson
From tire rack this is the info I found for what I have vs going to 35.
35 series 28.1in vs 30 series 27in rear
Front 35 series 27.3 vs 30 series 26.3
Old Feb 15, 2022 | 07:30 PM
USAZR1's Avatar
USAZR1
That is incorrect. A C5's AH/TC doesn't care what tire size you run, just don't fit a taller front tire than the rears.
Old Feb 15, 2022 | 08:19 PM
Mr. Black's Avatar
Mr. Black
No Hostility Be Happy
I'm not quite sure what kind of look you are going for because IMO that fender gap is not that bad.
Old Feb 15, 2022 | 08:29 PM
USAZR1's Avatar
USAZR1
I thought the same thing.
Old Feb 16, 2022 | 09:05 AM
Geardownson
Right now I can fit about 3 fingers between the fender and the tire. I like it at about 1 or 1 and a half..
To Having different tire sizes a bad idea?
