Gen III Iron Block Build
. I know installing a stroker is going down a rabbit hole of new clutch, upgraded six speed, torque tube and rear but those parts are apparently weaker on the early C5s and I think my belleville washers are going (gone?) anyway...so rebuilding the rear end with C6 parts is in the near future anyway. I don't plan on drag racing much but would like to get more into autocross and maybe a little spirited street driving sometimes. I've built quite a few small/big blocks in my time and have all the tools needed for the build.
My main question is if anyone has really noticed having an iron block vs aluminum up front. Thoughts?
I would not worry about the weight at all. The previous car drove extremely well, I did plenty of spirited street driving in it and 100% enjoyed it. The guys I sold it to got pretty serious about track events and that iron-block car was/is very competitive even in tight auto-x courses with real fast weight transfer. They did relocate the battery and also added a lot of coolers & such which added weight as well.
edit: I think the 5.3L LM4 is also a gen 3 aluminum block
But yes it could be a good replacement engine.
For $4999.00 you can get the LS3 long block engine in stock form that’s rated for 430-436 hp in C6 vetted depending on exhaust bypass.
Of course with this engine you need LS3 intake and same things mentioned above plus a Lingenfelter converter box to convert 58 tooth to 24 tooth.
For more $ they offer LS3 long block with GM hot cam, rated at 495 hp, or LS3 long block with ASA cam rated at 525, have heard of tuning issues on both of these with hot cam and ASA cam, I would choose the stock cam version and it it wasn’t enough, down the road upgrade to a cam that suits the car it’s in.
Early 6.0 lq4 or lq9 should bolt in and accept LS1-LS6 intake and all sensors work with original LS1 harness.
I requested price 05/08/2019 for this setup, back then no price was listed.
At the time I was quoted $2200.00, wish I had bought but didn’t have the extra $$.
CONTACT REQUEST #692306
Mike05/07/2019 02:19PM
I was wondering how much this short block is, thank you.
Chris @ Scoggin Dickey Parts Center
05/08/2019 08:07AM
2200.00”
