Brake diagram
so there are lines leaving the master cylinder that go to what I imagine is a proportion valve? This is located right under the master cylinder and also has 2 connectors plugged into sensors..Then there are lines leaving this block and going to another system between the alternator and the rad..( these are the lines in question that need to be replaced)
based on diagrams on google and not being able to find this exact setup can someone provide a diagram that sounds like what I am describing or confirm that someone modified something in the engine bay in the past 22 years?
thanks in advance
