[Z06] Clutch Curiosity
Seems to me that the clutch pedal feel changes when the clutch is actuated in rapid succession. Is this because of an in-line diaphragm that I have heard about in the hydraulic system? Someone once asked me if I had drilled out this diaphragm. Of course I had not and was not aware of the problem until recently. I now notice the pedal feel changes from time to time. Especially when on the road course.
Any advice? Thanks in advance!
:seeya
Debris in the system from cup rubber wear essentially thickens the fluid and might result in the inconsistency you report. A thorough flush of the clutch system will probably help. Prior to flushing, siphon all the old fluid out of the reservoir and use clean Q-tips to swab out the bottom and remove all the debris you will probably find.
Duke
[Modified by SWCDuke, 6:57 PM 12/30/2002]
