Harmonic Balancer Wobble
Old Mar 17, 2022 | 07:14 PM
Cruss127's Avatar
Cruss127
Default Harmonic Balancer Wobble
Hello all,
I am the recent purveyor of a C5 from a forum member. I have been doing my fair share of routine and preventative maintenance when I noticed a new squeal coming from the engine bay. I know C5s are notorious for squeal but this started out of no where. I just removed and cleaned the MAF, Throttle Body, and air filter. So I know I didn't touch or go near any belts to affect them. Attached is a video I took after a short and very squeaky drive. Does this look like HB wobble? I marked the HB with lines to see if there any misalignment and they're all still aligned after a month or so.
Old Mar 17, 2022 | 10:33 PM
RedC5's Avatar
RedC5
The AC pulleys also like to squeal so if you haven’t changed it try these first along with new belt. My pulleys spun like roller blade wheels (shot!).
Old Mar 17, 2022 | 10:51 PM
vette4fl's Avatar
vette4fl
Originally Posted by Cruss127
Hello all,
Do not see a video…
Old Mar 18, 2022 | 08:49 AM
Fast one's Avatar
Fast one
Does the squeal begin when you start the engine then fade away, or is it constant when the engine is running?
Old Mar 18, 2022 | 10:02 AM
grinder11's Avatar
grinder11
Most squealing is the belts, and then it's usually related to antifreeze being spilled on them, most times due to a T-stat change. I still have my original idler pulleys and tensioner, over 20 years old, 124,000 miles. They wheels have worn to the point that there's a slight wear spot on the plastic on the wheel surface. which consequently causes a very slight diameter reduction!!!. I still have no belt squealing........
Old Mar 19, 2022 | 12:28 AM
Dads2kconvertible's Avatar
Dads2kconvertible
One of these stethoscopes can help you pinpoint the source. I'd bet on belt tensioner if I had to guess.
https://www.autozone.com/test-scan-a...ve-stethoscope
Old Mar 19, 2022 | 10:13 AM
Cruss127's Avatar
Cruss127
Thanks all for the replies. I will take a new video since i thought I attached one. Its instant at start up. All the hash marks I drew on the balancer are still lined up too. Ill change the idle tensioner first and hope thats it. The wobble itself seems very slight but i know everyone saysnit has to jabe literally zero wobble.
To Harmonic Balancer Wobble
