[Z06] ROYAL FLUSH all fluids
Old Mar 21, 2022 | 09:42 AM
shipahoy's Avatar
shipahoy
Default ROYAL FLUSH all fluids
Scheduled an appointment for my 2004 ZO6 Corvette at Corvette Care in Columbus Ohio prior to any Autocross events this year.
They have very good reviews at Corvette Care.
ROYAL FLUSH, Power Steering System Flush & Fill, Drain Rear End, Refill, & Add Gear Oil Stabilizer, Brake Fluid Flush & Bleed (Dot 4), Manual Transmission Oil Change & Clutch Hydraulic Fluid Flush & Bleed, Plug & Wire Service, Drain, Flush, & Fill Cooling System, BRAKE UPDATE Technician Labor to install Customer Provided Pads & Rotors, Dyno Tune.
Old Mar 21, 2022 | 12:49 PM
MWWarlord's Avatar
MWWarlord
St. Jude Donor '21-'22
Your car looks great! That certainly is a comprehensive maintenance package. How much did that run you?
Old Mar 21, 2022 | 02:21 PM
I agree - sound like it will take care of all the fluids in one service.
Old Mar 29, 2022 | 10:14 AM
C5vett510's Avatar
C5vett510
how much does this service cost id love to do it yearly
Old Mar 29, 2022 | 04:37 PM
rrwirsi's Avatar
rrwirsi
Like I do with all my cars, fluid changes are done according to manufactures requirements. With the C5 vette, I do an addition change with the clutch fluid using the ranger method every year. No fluid problems for the 7+ years of ownership.
Old Mar 30, 2022 | 02:02 PM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
Your car's a beauty...and receiving good care!
Old Apr 3, 2022 | 06:19 PM
bc6152's Avatar
bc6152
What was the cost for these services?
Old Apr 4, 2022 | 07:32 AM
shipahoy's Avatar
shipahoy
ROYAL FLUSH
Old Apr 4, 2022 | 11:27 PM
rhneff's Avatar
rhneff
You probably know this already but depending on what organization you'll be autocrossing with, the tune might be problematic. The car looks stock but tuning the engine is not legal for SCCA Street classes so if with SCCA the custom tune would bump you out of Street class and into a higher prep category against cars with lots more mods.
Old Apr 5, 2022 | 09:26 AM
shipahoy's Avatar
shipahoy
SCCA SOLO, but I can't find that stipulation in the 2022 rule book.
Old Apr 6, 2022 | 08:53 AM
shipahoy's Avatar
shipahoy
Because of the rain I had it towed to Corvette Care in Columbus Ohio. Nation wide car carriers are good but I needed definite pickup and delivery days and times. Plus the guy that owns the towing service is a real nice guy and I can help a local business..
So far, techs found a bad water pump so that's getting replaced too. Plugs need changing but the plug wires are good.
Old Apr 6, 2022 | 09:19 AM
shipahoy's Avatar
shipahoy
I am a rookie to autocross. Can you please help me and quote the rule that you are referring to?
Thank you.
Old Apr 6, 2022 | 10:09 AM
Mikado463's Avatar
Mikado463
all good, but don't let any Ford guys see that pic, they might get the wrong idea ......
Old Apr 6, 2022 | 10:11 AM
Mikado463's Avatar
Mikado463
ROYAL FLUSH
sorry but the courtesy insp and shop supply fee twice ?? !! rip off IMO !!
Old Apr 6, 2022 | 11:14 AM
rhneff's Avatar
rhneff
Thank you.
The Solo Rules are sometimes a bit obtuse, but the framework used is "if it doesn't say you can, then you can't". Street Category, Page 73, says "Except for modifications authorized below, Street Category cars must be run as specified by the manufacturer . . ." There is no allowance anywhere in the Street Category rules for tuning the ECU, thus it doesn't say you can so you can't.
If you're only running local events it's probably not a big deal, especially if you're new to the sport because you're not likely to win unless you're running in a regional novice class. And a tune alone, without add-ons like headers/head-cam/etc., is not going to have much of an effect. Just thought you should be aware.
Old Apr 6, 2022 | 11:22 AM
shipahoy's Avatar
shipahoy
Hypotheic question.
So if someone bought a used car with headers and catless Xpipe and you don't know if the previous owner got a tune you could be moved up in class?
Thanks.
Old Apr 6, 2022 | 10:13 PM
rhneff's Avatar
rhneff
The headers alone would bump you out of Street Class (as well as removal of the cats), in which case a tune wouldn't matter. But for local events you may be over-thinking this. Just go run your car in A Street (assuming you're on 200TW or higher tires) and see how things go. If/when you start beating others then think about bringing the car into compliance, but no big deal when you're just learning. As in most forms of automobile competition, Solo is way more about the driver than the car.
To ROYAL FLUSH all fluids
Old Apr 7, 2022 | 07:44 AM
shipahoy's Avatar
shipahoy
So no one has headers in CAMS which is what I plan on running.
Old Apr 7, 2022 | 08:10 AM
snaitaz@aol.com's Avatar
snaitaz@aol.com
Good Day To All,
@Mikado463 I'm confused as I do not see courtesy inspection and shop supplies twice. Maybe I am getting older and just can't see all too well but the first column is the rate and the second column is the total for that section. So if you are referring to the $82.98 indicated twice you are correct except he was only charged once.
Cheers!!!
Old Apr 7, 2022 | 08:31 AM
Mikado463's Avatar
Mikado463
Originally Posted by snaitaz@aol.com
Good Day To All,
Cheers!!!
No, look further down the first column , to another 3.5% charge for misc shop supplies !
