HVAC control
Old Mar 25, 2022 | 09:16 AM
bricopeland36's Avatar
bricopeland36
4th Gear
Default HVAC control
Hey everyone !
I have a 98 C5 convertible ... I currently have the basic 3-dial hvac unit.
Its not working properly anymore... the dials sorta just keep turning.
I was hoping someone would be able to tell me if the other model hvac will work in a swap ... I'd like to put in the model that has the digital temperature reading and the driver/passenger dials.
Will that model work in my car ?
THANKS IN ADVANCE EVERYONE !
Brian
Old Mar 25, 2022 | 09:45 AM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
No, can’t be swapped over !!
Old Mar 25, 2022 | 02:22 PM
SilverC54me's Avatar
SilverC54me
Sounds like you may need some new *****. The rotary controls are available to replace the ones in you car also if those are bad.
Gary
Old Mar 26, 2022 | 11:38 AM
Would be great if it were as easy as just swapping the dual zone unit for the base one, but unfortunately I think it is a lot more complicated than that. I do not recall seeing a thread where such a swap has been tried. If it is just the ***** that are the problem, hopefully you can find a replacement set and solve the problem.
Old Nov 21, 2022 | 01:48 PM
sonicss33's Avatar
sonicss33
Gary
Do you or anyone know of a source to purchase just the 3 *****? I am diligently searching and coming up with nothing so far. Plenty of replacements for the 2 **** controls. TIA.
Old Nov 22, 2022 | 11:25 PM
Alley Oop's Avatar
Alley Oop
Vettenuts.net, they can probably help you out.
Old Dec 8, 2022 | 03:57 PM
sonicss33's Avatar
sonicss33
Still searching for just the *****. Marc at Vettenuts cannot get them and he is also looking for a source.
To HVAC control
