MGW Shifter
Old Mar 30, 2022 | 03:58 PM
bstallion's Avatar
bstallion
Cruising
Default MGW Shifter
I got my first Corvette (C5) a few weeks ago. The one thing I disliked the most was the extremely "loose" feel to the shifter. Sometimes I would hit fourth trying to get into second because it was so sloppy. From what I read on the stock shifter, apparently its a common issue on the C5. I ordered an MGW Shifter and Lower Box and that 100% solved the problem. Not only does it feel so much better but there is no mistake while going into gear now.
My Install:
Old Mar 30, 2022 | 04:43 PM
STRMLNE's Avatar
STRMLNE
Was probably it the skip shift making you hit 4th instead of 2nd.
Old Mar 30, 2022 | 05:01 PM
bstallion's Avatar
bstallion
Cruising
It's possible I guess. Whatever it was, I don't have any issue getting the gear I want now.
Old Apr 4, 2022 | 08:54 AM
ZEEZERO-6's Avatar
ZEEZERO-6
it's just a matter of time, eliminate the skip shift ...
To MGW Shifter
