I have 2, 6-8” pencil width deep scratches on my lower rocker panel I want to repair. Not noticeable to most but they are to me! Because of the location I want to try to fix myself versus the $600 quote I got from a body shop. Are the steps below correct? What grit sandpaper, wet or dry do I use for steps 1, 2, 5, 8 and 9? Any other suggestions? Thanks for your input.
1) Sand scrape to remove rough edges, feather…. U shape versus V shape.
2) Sand/feather area approximately 1-2” beyond, above and below scratch.
3) Clean
4) Fill scratch using USG SMC/Fiberglass Filler.
5) Sand after dried.
6) Reapply filler and sand as needed.
7) Prime?
8) 3 coats color matching paint, sanding in between coats.
9) 3-4 coats of Clear Coat, sand in between?
10) Polish and Wax
If you think you're the only one who can notice it now, just wait until you try to do the repairs yourself. If you've never done paint/body before you will run a higher risk of making it look worse, which at that point more people will notice it instead of just you. I would pay the $600. It'll save you the aggravation of spending the money for materials, the time doing the repairs, not being happy with it and then ultimately taking it to the shop anyway.
Sand after primer and then NO sanding after color coats or clear. Wait 10-15 minutes between coats, and 1 hour between color and clear. The bond between base and clear is a chemical reaction and does not need sanding.
From: Philadelphia PA (Birthplace of the USA, UNESCO World Heritage City)
Are you speaking from experience, or fear? Many on this forum have done DIY paint/body work successfully. Your same argument could be made for mechanical repairs.
