C6 Shifter in C5 Corvette
Old Apr 20, 2022 | 05:29 AM
Shovels and Vettes's Avatar
Shovels and Vettes
Default C6 Shifter in C5 Corvette
Been lurking and considering buying a C5 Corvette, and I see a very common modification that owners install a C6 shifter in their C5 manual Corvettes. Why do folks do that? What is the benefit, and is there something inherently wrong with the stock C5 shifter.
Old Apr 20, 2022 | 05:56 AM
4XLR8N's Avatar
4XLR8N
Pro Mechanic
The OEM C5 shifter is, shall we say, a bit sloppy.
To be fair, it isn't the worst shifter in the world, but it falls way short of what a sports car like the C5 should have.
Many, including myself, have installed the MGW. It is precise and a bit notchy, if you like that feel. The C6 shifter is about halfway between a C5 shifter and the MGW.
Old Apr 20, 2022 | 09:33 AM
LSgoBRRR's Avatar
LSgoBRRR
Worth noting that the C6 will sit a little tall... I would also recommend the MGW but am biased:
Old Apr 20, 2022 | 11:34 AM
MetalMan2's Avatar
MetalMan2
C6 shifter sits taller than aftermarket options but definitely lower than the original C5 shifter. (BTW that **** on the traction control plate looks familiar )
I run a C6 shifter with TMOD-upgraded lower shifter box. It is SUBSTANTIALLY nicer than the C5 shifter, because this lower box has zero slop and the stock C5 **** is grotesque (personal opinion).
Previously I had a MGW shifter with C6 ****. No doubt it's a nice shifter, but I prefer the stock C6 shifter with TMOD box.
Old Apr 20, 2022 | 08:06 PM
vette4fl's Avatar
vette4fl
I have same setup. Very happy with it.
Old Apr 21, 2022 | 04:10 AM
Shovels and Vettes
Thanks for the input guys.
Old Apr 21, 2022 | 09:11 AM
jackthelad's Avatar
jackthelad
Most people compare a well worn C5 shifter set up with a brand new C6 version. Guess what? the old one is sloppy. I tried a C6 shifter, but went back to a rebuilt stock set up, but with a shortened lever and an aftermarket shift ****. The C6 set up moves the **** rearward, as there is a rearward "bend" in the lever. Not a lot, but I preferred it where it was.
To C6 Shifter in C5 Corvette
