[Z06] Best lowering kit?
Old Jan 1, 2003 | 03:20 PM
Baltic Supra TT's Avatar
Baltic Supra TT
Default Best lowering kit?
Topic pretty much explains. I know you can just loosen the bolts and get it lower. But I am just going to go ahead and get the kit. Is there any out there that are better that others?
Chris
Old Jan 1, 2003 | 04:58 PM
Racer's Avatar
Cruise-In III Veteran
St. Jude Donor '11
Default Re: Best lowering kit? (Baltic Supra TT)
To be honest, you are wasting money buying a kit. You can buy everything you need from a local bolt supply store for less than $10 dollars. But if you want to spend the money, I think all the kits are the same with their urethane bushings and Grade 8 bolts for $50 You can get them from most of the supporting vendors. :cheers:
Old Jan 1, 2003 | 06:02 PM
Baltic Supra TT
Default Re: Best lowering kit? (racer44)
Anyone know what size bolts, nuts, ect. I need?
Old Jan 6, 2003 | 09:43 PM
inferno's Avatar
inferno
7 inch by 1/2 Grade 8. You need 2 and two locking nuts. Also get 4 washers. Should cost just under $10
[Modified by inferno, 8:44 PM 1/6/2003]
Old Jan 11, 2003 | 11:49 PM
davidmax's Avatar
davidmax
Default Re: Best lowering kit? (inferno)
We sell the kit for under 30.00 and price is negotiable.Its around 16.00 in hardware and 5.00 in packaging advertisising etc and will bring the car down 2" on all 4 corner.And as usual we will meet or beat any Corvette Forum price 90%+ of the time.480-517-4969,Thanks Dave S.
Old Jan 12, 2003 | 11:28 AM
John Shiels's Avatar
John Shiels
From: Buy USA products! Check the label! Employ Americans
My personal feeling is the stock bolts go far enough to let the suspension work properly. I road race and I am completely satisfied in stock bolts. If being low for looks is the main objective then do it but it will be low and may cause some damage. Don't forget alignment no matter you choose!
Old Jan 12, 2003 | 05:11 PM
Garceeya's Avatar
Garceeya
So Chris did you buy a vette yet? Last I heard you were not going to be able to buy one. Huh, I guess you were wasting my time. :mad I hope you get what you want. :rolleyes:
To Best lowering kit?
