1999 battery/memory impacts
Old May 14, 2022 | 02:50 PM
oldspeedr's Avatar
oldspeedr
Default 1999 battery/memory impacts
This likely exists somewhere in the forums so I apologize if it's repetitive. Just disconnected my battery for first time since buying the car last October. Had it disconnected for about 15 minutes while I removed an old crusty mat from underneath, checked the passenger cowl drain udder and installed a formerly missing hold down. Only things that appeared to be affected by the disconnect were:. Clock (radio settings were fine), hud options and I had to relearn the fobs. Not a major inconvenience. My car does have the memory package AAB.
Old May 14, 2022 | 03:19 PM
c5arlen's Avatar
c5arlen
Yes that is correct.
Old May 14, 2022 | 08:44 PM
Americal's Avatar
Americal
Whenever I have to disconnect the battery, I hook up a small charger thru the lighter socket so the car never loses it's 12 volts.
To 1999 battery/memory impacts
